This teardown is not a repair guide. To repair your LG G Watch R, use our service manual.
  1. LG G Watch R Teardown, Front and Back: step 1, image 1 of 2 LG G Watch R Teardown, Front and Back: step 1, image 2 of 2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: step 2, image 1 of 2 LG G Watch R Teardown, Removing the back cover: step 2, image 2 of 2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: step 3, image 1 of 2 LG G Watch R Teardown, Removing the Board: step 3, image 2 of 2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: step 4, image 1 of 2 LG G Watch R Teardown, The Battery: step 4, image 2 of 2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: step 5, image 1 of 1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: step 6, image 1 of 3 LG G Watch R Teardown, P-OLED Panel: step 6, image 2 of 3 LG G Watch R Teardown, P-OLED Panel: step 6, image 3 of 3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
Dustin Richards
332 Reputation
1 Guide authored
8 Comments
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - Reply
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - Reply
Where could I find a battery for replacement?
Thanks in advance.
Fab - Reply
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 20,311
