Introduction
Go to step 1
I have tried to include as much detail as possible in this teardown. I have even inspected the chips on the mainboard! Thanks for looking, and I hope you find this useful.
This teardown is not a repair guide. To repair your LG GW300, use our service manual.
  1. LG GW300 Teardown, LG GW300 Teardown: step 1, image 1 of 1
    • Found this phone lying around, so decided to make a teardown of it!
  2. LG GW300 Teardown: step 2, image 1 of 1
    • First, remove the backplate by pushing the button at the top of the back of the phone.
  3. LG GW300 Teardown: step 3, image 1 of 3 LG GW300 Teardown: step 3, image 2 of 3 LG GW300 Teardown: step 3, image 3 of 3
    • From here there are six screws we have to remove.
    • But first... lemme take a battery out!
  4. LG GW300 Teardown: step 4, image 1 of 1
    • Get a thin opening tool and slide it around the bezel of the device.
    • Make sure you put it in the correct place, behind the silver bezel of the front of the phone!
  5. LG GW300 Teardown: step 5, image 1 of 1
    • The front and back of the device should separate.
    • Two buttons should come off after you have removed the back.
    • This is the rear speaker.
  6. LG GW300 Teardown: step 6, image 1 of 3 LG GW300 Teardown: step 6, image 2 of 3 LG GW300 Teardown: step 6, image 3 of 3
    • Both of these buttons need to be pried from the front casing to allow the mainboard to come away from the front housing.
    • These buttons are soldered to the mainboard so make sure you don't break them!
    • The front speaker also has to be pried from the front housing.
  7. LG GW300 Teardown: step 7, image 1 of 2 LG GW300 Teardown: step 7, image 2 of 2
    • The main board can then be lifted from the front housing.
  8. LG GW300 Teardown: step 8, image 1 of 1
    • The buttons on the front housing can then be pushed out through the back of the housing.
  9. LG GW300 Teardown: step 9, image 1 of 2 LG GW300 Teardown: step 9, image 2 of 2
    • The EMI shield can be removed by unclipping the clips on the side of the device.
  10. LG GW300 Teardown: step 10, image 1 of 2 LG GW300 Teardown: step 10, image 2 of 2
    • In the centre of the picture is the vibration module. It can be unclipped to remove it.
  11. LG GW300 Teardown: step 11, image 1 of 3 LG GW300 Teardown: step 11, image 2 of 3 LG GW300 Teardown: step 11, image 3 of 3
    • The LCD ribbon cable and connector are under a plastic sheet that has to be removed.
    • The ribbon cable can then be take out of the connector
    • The ribbon connector is very fragile, so be careful when lifting the lever.
  12. LG GW300 Teardown: step 12, image 1 of 2 LG GW300 Teardown: step 12, image 2 of 2
    • Use a thin opening tool to separate the LCD from the main board.
    • Do this slowly and carefully as the screen can easily crack or bleed.
  13. LG GW300 Teardown: step 13, image 1 of 1
    • Chip inspection time!
    • Mediatek ARM MT6A01AA
    • Samsung K5D1H12ACC-A075 NAND flash memory
    • Skyworks Solutions SKY77524-15
    • CSR 51E130A14U
James
185 Reputation
1 Guide authored
One Comment
Now if only I could find the datasheet/pinout for the "Mediatek ARM MT6A01AA"...
River Saxton - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,451
