This teardown is not a repair guide. To repair your LG Optimus L9 P760, use our service manual.
  1. LG Optimus L9 P760 Teardown, LG Optimus L9 P760 Teardown: step 1, image 1 of 2 LG Optimus L9 P760 Teardown, LG Optimus L9 P760 Teardown: step 1, image 2 of 2
    • Released in 2012 as the best phone in the L series (the other phones were L3, L5 and L7)
    • This phone exists in different versions : the P760 (this one), the P765 (for India), P768 (for America - and a 8 MP camera) and P769.
    • The specs of this phone :
    • CPU: Cortex A9 (dual-core @ 1 GHz)
    • RAM: 1 GB (0.75 GB according to the phone)
    • Storage: 4 GB (2.3 GB usable) + micro-SD
    • Screen: 4.7" IPS, 540x960.
    • OS: Android 4.1.2 (for the latest version - 4.2 with Cyanogen 10.1.2)
  2. LG Optimus L9 P760 Teardown: step 2, image 1 of 2 LG Optimus L9 P760 Teardown: step 2, image 2 of 2
    • To access to the battery: easy: let it drop or lift with your thumbnails the rear cover.
    • The battery can be removed the same way (dropping the phone is not a good idea...)
    • The battery has a capacity of 2150 mAh. Not that bad but it runs out quite quickly (good point: the battery is removable)
  3. LG Optimus L9 P760 Teardown, Removing the lower part: step 3, image 1 of 3 LG Optimus L9 P760 Teardown, Removing the lower part: step 3, image 2 of 3 LG Optimus L9 P760 Teardown, Removing the lower part: step 3, image 3 of 3
    • Let's begin the fun part: with a screwdriver, let's remove the three Philips screws.
    • Keep the screws on a magnet not to lose them (or two: there are two types of screws in this phone: the little short and the little long screws)
    • This part can be lifted easily (eg: insert a flat screwdriver on the top of the part)
  4. LG Optimus L9 P760 Teardown: step 4, image 1 of 3 LG Optimus L9 P760 Teardown: step 4, image 2 of 3 LG Optimus L9 P760 Teardown: step 4, image 3 of 3
    • What does this part do?
    • The vibrator which... well, vibrates.
    • And the bottom speaker: used when you listen to music and with hands-free calls).
    • From the rest of the phone, the connectors are visible.
  5. LG Optimus L9 P760 Teardown, Removing the cache: step 5, image 1 of 3 LG Optimus L9 P760 Teardown, Removing the cache: step 5, image 2 of 3 LG Optimus L9 P760 Teardown, Removing the cache: step 5, image 3 of 3
    • Now, to access to the motherboard and to the connectors, you are at 7 screws from it!
    • With a spudger (or something flat - NOT a flat screwdriver), pry the glossy part and separate it from the rest of the phone.
    • As a rule of thumb, a rule is somehow effective!
  6. LG Optimus L9 P760 Teardown: step 6, image 1 of 3 LG Optimus L9 P760 Teardown: step 6, image 2 of 3 LG Optimus L9 P760 Teardown: step 6, image 3 of 3
    • Here we are! Before removing the lower card, let's remove the two little screws and the cache hiding the micro USB port.
    • The phone, with the guts visible (almost...)
  7. LG Optimus L9 P760 Teardown, Removing the bottom board: step 7, image 1 of 3 LG Optimus L9 P760 Teardown, Removing the bottom board: step 7, image 2 of 3 LG Optimus L9 P760 Teardown, Removing the bottom board: step 7, image 3 of 3
    • To proceed, detach the antenna and the connector.
    • Then, the tedious part: the board is glued to the case! Proceed wit care not to break the card (by taking the part and with a spudger).
    • We can note the presence of the (little) microphone. This board gathers the connectors for the vibrator, the speaker, the micro USB and the antenna. This part is quite important!
  8. LG Optimus L9 P760 Teardown, Removing the motherboard: step 8, image 1 of 2 LG Optimus L9 P760 Teardown, Removing the motherboard: step 8, image 2 of 2
    • Now, the (dual-)core of the phone: the motherboard. LG was good for the board: almost everything is linked by connectors, easily removable!
    • Let's continue our dissasembly by disconnecting the four remaining ribbons:
    • The digitizer
    • The screen
    • The rear camera
    • The front camera and the proximity sensor
    • The antenna. Useful if the antenna was torn because it is easily replaceable!
    • Is it me or the phone includes a second antenna for dual-SIM models?
  9. LG Optimus L9 P760 Teardown: step 9, image 1 of 3 LG Optimus L9 P760 Teardown: step 9, image 2 of 3 LG Optimus L9 P760 Teardown: step 9, image 3 of 3
    • Careful, the board won't go without unscrewing this tiny screw, securing the top speaker (sorry for the quality)!
  10. LG Optimus L9 P760 Teardown: step 10, image 1 of 2 LG Optimus L9 P760 Teardown: step 10, image 2 of 2
    • The motherboard, with the shields. With a flat screwdriver (do it if the phone is dead... Otherwise, the components beneath are fragile and may stop working).
    • I don't want to say wrong things so the analysis is left as an exercise for the reader.
  11. LG Optimus L9 P760 Teardown, Removing the digitizer: step 11, image 1 of 2 LG Optimus L9 P760 Teardown, Removing the digitizer: step 11, image 2 of 2
    • The most interesting part for a fragile phone: the digitizer.
    • The connector of the digitizer can cause you trouble! Don't lift the digitizer brutally or the ribbon may tear!
    • Little by little, with a spudger, the both parts start separating... Be careful though!
  12. LG Optimus L9 P760 Teardown: step 12, image 1 of 2 LG Optimus L9 P760 Teardown: step 12, image 2 of 2
    • Here is it! It includes the two capacitive buttons on the bottom.
    • The button is barely maintained on the digitizer!
  13. LG Optimus L9 P760 Teardown, Removing the camera: step 13, image 1 of 3 LG Optimus L9 P760 Teardown, Removing the camera: step 13, image 2 of 3 LG Optimus L9 P760 Teardown, Removing the camera: step 13, image 3 of 3
    • The rear camera is glued to the naked phone. A flat screwdriver and the camera is gone!
  14. LG Optimus L9 P760 Teardown, The female Jack: step 14, image 1 of 1
    • The female Jack connector is not soldered at all! Only on its place, with the four connectors touching thr motherboard.
  15. LG Optimus L9 P760 Teardown: step 15, image 1 of 2 LG Optimus L9 P760 Teardown: step 15, image 2 of 2
    • This teardown is completed (almost).
    • Feel free to add information if you want!
    • Rest in Pieces, phone...
Bob
760 Reputation
3 Guides authored
One Comment
how to make a battery?
Ziyad Ziyad - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 2,637
