This teardown is not a repair guide. To repair your LG Optimus L9 P769, use our service manual.
  1. LG Optimus L9 P769 Teardown, LG Optimus L9 P769 Teardown: step 1, image 1 of 2 LG Optimus L9 P769 Teardown, LG Optimus L9 P769 Teardown: step 1, image 2 of 2
    • Here's what LG's L9 P769 holds hardware-wise:
    • Dual-core 1.0 GHz CPU
    • 4.5 inch IPS LCD with a resolution of 540 x 960 pixels
    • 4 GB of internal storage
    • 5MP Primary camera and VGA front facing camera
    • Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, hotspot, DLNA
  2. LG Optimus L9 P769 Teardown: step 2, image 1 of 1
    • Power off the device and gently lift the battery cover off to access the battery
  3. LG Optimus L9 P769 Teardown: step 3, image 1 of 1
    • Lift and remove the battery from the notch in the edge of the battery compartment
  4. LG Optimus L9 P769 Teardown: step 4, image 1 of 2 LG Optimus L9 P769 Teardown: step 4, image 2 of 2
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using the PH000 headtype
  5. LG Optimus L9 P769 Teardown: step 5, image 1 of 2 LG Optimus L9 P769 Teardown: step 5, image 2 of 2
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  6. LG Optimus L9 P769 Teardown: step 6, image 1 of 2 LG Optimus L9 P769 Teardown: step 6, image 2 of 2
    • Carefully remove vibration and speaker module using the prying tool
  7. LG Optimus L9 P769 Teardown: step 7, image 1 of 3 LG Optimus L9 P769 Teardown: step 7, image 2 of 3 LG Optimus L9 P769 Teardown: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Remove both connections of the antenna by pulling up with tweezers
  8. LG Optimus L9 P769 Teardown: step 8, image 1 of 3 LG Optimus L9 P769 Teardown: step 8, image 2 of 3 LG Optimus L9 P769 Teardown: step 8, image 3 of 3
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  9. LG Optimus L9 P769 Teardown: step 9, image 1 of 2 LG Optimus L9 P769 Teardown: step 9, image 2 of 2
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  10. LG Optimus L9 P769 Teardown: step 10, image 1 of 1
    • Remove screw at top of phone to release speaker with PH000 screwdriver
  11. LG Optimus L9 P769 Teardown: step 11, image 1 of 3 LG Optimus L9 P769 Teardown: step 11, image 2 of 3 LG Optimus L9 P769 Teardown: step 11, image 3 of 3
    • Use a small prying tool to release all motherboard connections.
  12. LG Optimus L9 P769 Teardown: step 12, image 1 of 1
    • Remove rear facing camera by using the small prying tool
  13. LG Optimus L9 P769 Teardown: step 13, image 1 of 2 LG Optimus L9 P769 Teardown: step 13, image 2 of 2
    • Gently lift the motherboard with small prying tool to remove and set aside
  14. LG Optimus L9 P769 Teardown: step 14, image 1 of 1
    • Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
    • Do not force open as the latches attaching the digitizer to the chassis as they are easily damaged.
  15. LG Optimus L9 P769 Teardown: step 15, image 1 of 2 LG Optimus L9 P769 Teardown: step 15, image 2 of 2
    • Carefully remove the digitizer from case by sliding out connected ribbon cable
  16. LG Optimus L9 P769 Teardown: step 16, image 1 of 1
    • Use a small prying tool to detach the screen circuitry from the case
  17. LG Optimus L9 P769 Teardown: step 17, image 1 of 3 LG Optimus L9 P769 Teardown: step 17, image 2 of 3 LG Optimus L9 P769 Teardown: step 17, image 3 of 3
    • Remove the remaining circuitry utilizing a smaller prying tool or a small flathead screwdriver
    • Carefully slide out circuity to remove phone display
  18. LG Optimus L9 P769 Teardown: step 18, image 1 of 1
    • Use tweezers to disconnect the 3.5mm headphone jack from the phone
  19. LG Optimus L9 P769 Teardown: step 19, image 1 of 3 LG Optimus L9 P769 Teardown: step 19, image 2 of 3 LG Optimus L9 P769 Teardown: step 19, image 3 of 3
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  20. LG Optimus L9 P769 Teardown: step 20, image 1 of 1
    • Full tear-down and recommended tools for procedure
Kayden G
272 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Spring 2017 Member of IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,832
