Teardown
This teardown is not a repair guide. To repair your LG Xpression C395, use our service manual.
Remove the back plate and battery
Remove the 7 Philips screws on the mid frame and un-clip it from the body
Take out the volume rocker daughter board, the black speaker plastic and the vibrate motor.
Remove the 2 Phillips screws and remove the motherboard
Remember there is a Ribbon cable under the motherboard
Remove the screen Ribbon cable and the keyboard
Remove the 4 Phillips screws holding in the keyboard plastic
Remove 4 more Phillips screws and remove the back of the screen
Remove the bottom button, earpiece and screen ribbon cable
After all of this you can remove the screen and conclude this teardown
with 1 other contributor
169 Reputation
1 Guide authored
Badges: 0
Business
1 Member
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 686
