This teardown is not a repair guide. To repair your Logitech M150 Mouse, use our service manual.
  1. Logitech M150 Mouse Teardown, Flip the mouse on it's back: step 1, image 1 of 1
    • Remove the battery door cover and flip the mouse on it's back
  2. Logitech M150 Mouse Teardown, Beginning the disassembly: step 2, image 1 of 2 Logitech M150 Mouse Teardown, Beginning the disassembly: step 2, image 2 of 2
    • Remove the two screws in the battery bay that hold the top grip to the base of the mouse.
    • Use a flat head screwdriver and wedge the blade in-between the top and bottom part of the mouse. There is a small cut-out to work with.
  3. Logitech M150 Mouse Teardown, Disassemble the grip: step 3, image 1 of 2 Logitech M150 Mouse Teardown, Disassemble the grip: step 3, image 2 of 2
    • Separate the top and bottom parts of the mouse
    • Remove the three Philips head screws holding in the forward/back buttons
  4. Logitech M150 Mouse Teardown, Remove the Forward/Back Buttons: step 4, image 1 of 2 Logitech M150 Mouse Teardown, Remove the Forward/Back Buttons: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers or your hands, carefully remove the plastic buttons by following the direction of movement in each image.
    • You need to make sure not to bend or pull too hard to remove the buttons.
  5. Logitech M150 Mouse Teardown, Remove the Left/Right click Buttons: step 5, image 1 of 3 Logitech M150 Mouse Teardown, Remove the Left/Right click Buttons: step 5, image 2 of 3 Logitech M150 Mouse Teardown, Remove the Left/Right click Buttons: step 5, image 3 of 3
    • Use a Philips screwdriver to remove the two remaining screws from the grip.
    • Then, gently pry the mouse button cover from the grip using a flat-edge screwdriver. There is just enough space to get a fine driver wedged in place.
    • Use your fingernails or a spudger tool to push each plastic tab back (green)
    • Lastly, slide the button check clips down and then up in the direction indicated by the arrows to remove the button cover from the grip.
  6. Logitech M150 Mouse Teardown, Remove the Button Cover: step 6, image 1 of 2 Logitech M150 Mouse Teardown, Remove the Button Cover: step 6, image 2 of 2
    • The grip and cover should be completely separated at this point
    • This is a good time to do some cleaning. You can wash all of the plastic components and scrub off any dirt.
  7. Logitech M150 Mouse Teardown, Remove the Scroll Wheel: step 7, image 1 of 3 Logitech M150 Mouse Teardown, Remove the Scroll Wheel: step 7, image 2 of 3 Logitech M150 Mouse Teardown, Remove the Scroll Wheel: step 7, image 3 of 3
    • Use a Philips screwdriver to lift the tip of the scrollwheel up and away from the top of base of the mouse
    • The clips holding it in place should click when you remove the wheel and should make a similar noise if you replace them
  8. Logitech M150 Mouse Teardown, Remove the Battery Bay: step 8, image 1 of 3 Logitech M150 Mouse Teardown, Remove the Battery Bay: step 8, image 2 of 3 Logitech M150 Mouse Teardown, Remove the Battery Bay: step 8, image 3 of 3
    • Insert a flathead screwdriver into the narrow gap between the clasp of the battery bay and the base of the mouse
    • Apply a fair amount of upward force to release the battery bay from the base
    • Next, remove the battery cable and slide the whole battery bay from the base of the mouse
  9. Logitech M150 Mouse Teardown, Remove the Logic Board: step 9, image 1 of 3 Logitech M150 Mouse Teardown, Remove the Logic Board: step 9, image 2 of 3 Logitech M150 Mouse Teardown, Remove the Logic Board: step 9, image 3 of 3
    • Use a Philips screw to remove the only screw securing the board to the base
    • Push the retaining clasps outwards and slide the whole logic board out at a 20 degree angle. It should not require any force and come free
  10. Logitech M150 Mouse Teardown, Disassembly Complete: step 10, image 1 of 1
    • Follow these steps in reverse to rebuild the mouse.
Emi
387 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 122
All Time: 4,679
