Logitech VX Revolution Teardown
  1. Logitech VX Revolution Teardown, Preparation: step 1, image 1 of 1
    • Remove the Wireless Adapter.
  2. Logitech VX Revolution Teardown, Remove screws: step 2, image 1 of 1
    • Remove the 5 skatepads carefully using a scalpel and tweezers or small pliers. Do not throw them away if you do not have a replacement at hand.
    • Do not throw away the skatepads, it is very difficult to find new ones.
    • Remove the 5 screws using a Phillips screwdriver (Size PH1).
  3. Logitech VX Revolution Teardown, Opening the mouse: step 3, image 1 of 1
    • Open the device as shown in the image without force.
    • You can remove the flex cable after carefully lifting the brown plastic part using finger nail or a small srew driver.
    • To remove the mouse wheel, the marked screw has to be removed using a PH1 screwdriver.
  4. Logitech VX Revolution Teardown, The Scroll Wheel: step 4, image 1 of 1
    • The assembly consists after the removal of the screw (left) of a plastic part laying on the PCB and the main assembly.
    • Furthermore, a small spring belongs to the assembly, which may be secured till reassembly by using a magnet.
  5. Logitech VX Revolution Teardown, The battery housing: step 5, image 1 of 1
    • The battery case lays loosely in top of the base assembly and is connected to the main PCB using a small connector.
  6. Logitech VX Revolution Teardown, The Transmitter Mount: step 6, image 1 of 1
    • The case for the transmitter isn't secured by any screw and can be removed by lifting it out of the mouse with very little force.
    • To remove the PCB board, unscrew the two screws using a PH00 bit.
  7. Logitech VX Revolution Teardown, The PCB Board: step 7, image 1 of 2 Logitech VX Revolution Teardown, The PCB Board: step 7, image 2 of 2
    • Backside of the PCB. The markings illustrate the positions of the mouse buttons (type D2FC-F-7N).
    • Contacts for the right mouse button. Desolder if neccessary.
    • Contacts for the left mouse button. Desolder if neccessary.
  8. Logitech VX Revolution Teardown, Steps for Reassembaly: step 8, image 1 of 1
    • Follow the previous steps in reverse for reassembly.
    • The mouse wheel assembly has a small metal pin in the front. This pin has to fit inside the hole in the loos plastic part.
    • It is recommended to combine the assembly and the plastic part before reinserting them to their final spot. Furthermore, the battery box shoud be assembled thereafter to simplify the process.
    • Check the functionality of the mouse before reapplying the skate pads.
Finish Line
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Florian Kleiner
340 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,643
