This teardown is not a repair guide. To repair your Mac Pro 2009-2012, use our service manual.
  1. Mac Pro Early 2009 Teardown, Mac Pro Early 2009 Teardown: step 1, image 1 of 1
    • I took the Mac Pro Apart.
  2. Mac Pro Early 2009 Teardown: step 2, image 1 of 1
    • added the PSU
  3. Mac Pro Early 2009 Teardown: step 3, image 1 of 1
    • added the backplane board
  4. Mac Pro Early 2009 Teardown: step 4, image 1 of 1
    • Front Panel Board
  5. Mac Pro Early 2009 Teardown: step 5, image 1 of 1
    • Here you can see the LEDs of the Mac Pros, and the DIAG_LED bottom
  6. Mac Pro Early 2009 Teardown: step 6, image 1 of 1
    • The front panel board to backplane board cable
  7. Mac Pro Early 2009 Teardown: step 7, image 1 of 1
    • another view of the front panel board
  8. Mac Pro Early 2009 Teardown: step 8, image 1 of 1
    • Another view of the backplane board
  9. Mac Pro Early 2009 Teardown: step 9, image 1 of 1
    • BackPlane Board and frontPanel Board linked by FrontPanel Board to BackPlane Board cable
  10. Mac Pro Early 2009 Teardown: step 10, image 1 of 1
    • Bluetooth antenna connected to the card on the Backplane board. One needs to be careful because if not connected the Antenna needs to be attached in order not to short-circuit the backpanel board.
  11. Mac Pro Early 2009 Teardown: step 11, image 1 of 1
    • A view of the PCI Slots on the Mac Pro Early 2009
  12. Mac Pro Early 2009 Teardown: step 12, image 1 of 1
    • Optical Drive Cables on BackPlane Board.
  13. Mac Pro Early 2009 Teardown: step 13, image 1 of 1
    • A view of the power button that needs to be connected on the front panel board.
  14. Mac Pro Early 2009 Teardown: step 14, image 1 of 1
    • Processor Cage
  15. Mac Pro Early 2009 Teardown: step 15, image 1 of 1
    • Left Fan in processor cage with speaker.
  16. Mac Pro Early 2009 Teardown: step 16, image 1 of 1
    • right fan in processor cage. Remember, two clips to take the a fan apart. Top and Bottom.
  17. Mac Pro Early 2009 Teardown: step 17, image 1 of 1
    • Unit with, PSU, BackPlane Board, Front Panel Board.
  18. Mac Pro Early 2009 Teardown: step 18, image 1 of 1
    • Small parts that cover the PSU and Super Drive cables.
  19. Mac Pro Early 2009 Teardown: step 19, image 1 of 1
    • Processor heatsinks 8 Core
  20. Mac Pro Early 2009 Teardown: step 20, image 1 of 1
    • Processor Heatsink 4 core
  21. Mac Pro Early 2009 Teardown: step 21, image 1 of 1
    • We can really see the difference between the 8 core and 4 core.
  22. Mac Pro Early 2009 Teardown: step 22, image 1 of 1
    • Processor Cage & Left and right Speakers.
  23. Mac Pro Early 2009 Teardown: step 23, image 1 of 1
    • A nice view of processor board 8 core.
  24. Mac Pro Early 2009 Teardown: step 24, image 1 of 1
    • CPU B of the processor Board.
  25. Mac Pro Early 2009 Teardown: step 25, image 1 of 1
    • CPU A of Processor Board.
  26. Mac Pro Early 2009 Teardown: step 26, image 1 of 1
    • Processor & HeatSink
  27. Mac Pro Early 2009 Teardown: step 27, image 1 of 1
    • RAID Card for Mac Pro Early 2009
  28. Mac Pro Early 2009 Teardown: step 28, image 1 of 1
    • Graphic Card
  29. Mac Pro Early 2009 Teardown: step 29, image 1 of 1
    • Fibre Channel Card
  30. Mac Pro Early 2009 Teardown: step 30, image 1 of 1
    • Finally the machine is rebuilt
zongo
453 Reputation
1 Guide authored
23 Comments
Hello,
I have Mac Pro 5,1 intel Xeon W3565 at 3.2 GHz Quad-Core.
It is easy to upgrade in W3565 at 3.33 GHz 6-Core ???
Any intel Xeon W3565 fit in my Mac Pro ?
What CPU sockets supported for ?
Thank you,
Stefanos.
StefMacGR - Reply
It is socket-b(LGA 1366)
I think it is easy to upgrade your CPU
sendercustom - Reply
It should be easy to upgrade a single-cpu Pro, they use standard lidded Xeons. I am planning on upgrading to W3690s in a couple of 4,1 machines that have had their firmware flashed to 5,1.
tobiasboyd - Reply
Please let me know how you handle that upgrade!! Or add a tutorial id vey much like to see that and maybe follow suit but im not very savy with these upgrades
Will -
Is it possible to easily remove and service right processor fan (the back one)? It makes too much noise, so needs some oil apparently. I didn't find any way to remove it.
Andriy Tevelyev - Reply
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 177
All Time: 116,529
