Featured Document
This teardown is not a repair guide. To repair your 15″ MacBook Pro (Early 2006), use our service manual.
  1. MacBook A1150 Teardown, Battery: step 1, image 1 of 1
    • Shut down the computer and disconnect the power cord and any other cables connected to the computer
    • Place the computer face down
    • Slide both battery latches away and lift the battery out
  2. MacBook A1150 Teardown, Memory: step 2, image 1 of 3 MacBook A1150 Teardown, Memory: step 2, image 2 of 3 MacBook A1150 Teardown, Memory: step 2, image 3 of 3
    • Remove the three screws from the memory door
    • Remove the door as shown
    • Remove the memory cards by carefully spreading the tabs away from the card
    • Pull the card straight back and out
  3. MacBook A1150 Teardown, Top Case: step 3, image 1 of 3 MacBook A1150 Teardown, Top Case: step 3, image 2 of 3 MacBook A1150 Teardown, Top Case: step 3, image 3 of 3
    • Remove the six screws on the bottom and the two in the battery bay
    • Remove the four screws from the side and two on the back
  4. MacBook A1150 Teardown, Top Case Cont.: step 4, image 1 of 3 MacBook A1150 Teardown, Top Case Cont.: step 4, image 2 of 3 MacBook A1150 Teardown, Top Case Cont.: step 4, image 3 of 3
    • Open the display slightly past 90 degrees and use a spudger to loosen the top case
    • A snapping noise is normal
    • Do not lift the top case once it is free
    • Slowly lift the top case until you can see the ribbon cable, carefully unplug then lift the top case off
  5. MacBook A1150 Teardown: step 5, image 1 of 2 MacBook A1150 Teardown: step 5, image 2 of 2
    • Remove two antenna connectors. Lift straight up
    • Remove one screw and bracket. The card should rise up slightly
    • Pull the card straight out
Attached Documents
Luke
1,613 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 25
Past 7 Days: 217
Past 30 Days: 620
All Time: 3,290
