This teardown is not a repair guide. To repair your MacBook Core 2 Duo, use our service manual.
  1. MacBook Core 2 Duo Rechargeable Battery Teardown, MacBook Core 2 Duo Rechargeable Battery Teardown: step 1, image 1 of 2 MacBook Core 2 Duo Rechargeable Battery Teardown, MacBook Core 2 Duo Rechargeable Battery Teardown: step 1, image 2 of 2
    • There are a total of 10 Torx T4 screws, five on each side.
  2. MacBook Core 2 Duo Rechargeable Battery Teardown: step 2, image 1 of 3 MacBook Core 2 Duo Rechargeable Battery Teardown: step 2, image 2 of 3 MacBook Core 2 Duo Rechargeable Battery Teardown: step 2, image 3 of 3
    • The metal bottom plate has some glue on it around the connector end. The opposite end can be lifted to help break it loose; it fits straight down.
    • Note the built in slots to hold the connector cards on the end.
    • The interior holds six battery packs; three stacks of two.
  3. MacBook Core 2 Duo Rechargeable Battery Teardown: step 3, image 1 of 1
    • Here you can see the stacks.
  4. MacBook Core 2 Duo Rechargeable Battery Teardown: step 4, image 1 of 3 MacBook Core 2 Duo Rechargeable Battery Teardown: step 4, image 2 of 3 MacBook Core 2 Duo Rechargeable Battery Teardown: step 4, image 3 of 3
    • Here you can see the two connector boards.
    • The white paste looking stuff is where the battery pack broke open and leaked.
  5. MacBook Core 2 Duo Rechargeable Battery Teardown: step 5, image 1 of 2 MacBook Core 2 Duo Rechargeable Battery Teardown: step 5, image 2 of 2
    • Here's a side and top view of the connector boards.
mayer
686,018 Reputation
12 Guides authored
MacHale Enterprises Member of MacHale Enterprises
Business
1 Member
19 Guides authored
5 Comments
For anyone who might need to know…
The pinouts on the aftermarket battery I have are labelled as follows…
P-, T, D, C, /, P+ This is reading right to left, holding the battery in front of you, right way up, with the pins facing towards you.
I interpret this to be, Power minus, Thermistor, Data, Clock, Switch, Power plus respectively.
The P- is connected directly to the negative of the battery. The P+ is not directly connected to the battery, but is connected via a solid state switch on the battery PC board.
Greg Lee - Reply
The "white paste looking stuff" is not a from a ruptured battery.
There's pictures of other batteries with it, mine has it, it is normal - probably an afterthough to stop wiring going astray or shorting out.
Gaz Rybagz - Reply
Anyone have the schematic for the lipo cells connection?
thevjfla - Reply
I have a question about this batter & im hoping someone will let me know if it’s a bad one so I can avoid damage lol.
anyway here it is: I dropped water on an old macbook I had completely rewinding the motherboard. This happened years ago and I know there’s no salvaging the computer itself but right before the accident happened, I had sent it out to Apple for warranty repair (unrelated to the batter) and they swapped my battery for a brand new one. So anyway I have a brand new batter and I’m wondering if I can use it as a power source for some LED light I have. I didn’t know the controller was inside until I opened the battery up. Anyway now I’m thinking that if I can (I hope I can) I’d like to see how I would go about drawing power from it as well as charging it without having to put it onto a computer. Help anyone?
Manny O - Reply
They are normal 3.7v li-ion polymer cells. Probably 2px3s (2 in parallel, 3 in series) So you could use them for lighting leds. There are hundreds of chargers/chargerboards for these kind of batteries on AliExpress or Ebay but you’ll probably need to do some soldering.
And of cause you need a driver for the leds if there is not already one included.
Maybe you can sell the battery. There are a lot of MacBooks with bad batteries out there ;)
Eduard van Raalte - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 100
All Time: 40,003
