Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
This teardown is not a repair guide. To repair your Medela Sonata Breast Pump, use our service manual.
  1. Medela Sonata Breast Pump Teardown, Medela Sonata Breast Pump Teardown: step 1, image 1 of 3 Medela Sonata Breast Pump Teardown, Medela Sonata Breast Pump Teardown: step 1, image 2 of 3 Medela Sonata Breast Pump Teardown, Medela Sonata Breast Pump Teardown: step 1, image 3 of 3
    • Remove the 4 hidden T10 screws.
    • Lift and remove the bottom cover from the pump.
  2. Medela Sonata Breast Pump Teardown: step 2, image 1 of 3 Medela Sonata Breast Pump Teardown: step 2, image 2 of 3 Medela Sonata Breast Pump Teardown: step 2, image 3 of 3
    • Remove the cable from the blue board with the power button and charging port.
  3. Medela Sonata Breast Pump Teardown: step 3, image 1 of 2 Medela Sonata Breast Pump Teardown: step 3, image 2 of 2
    • Remove cable from port on the side of the black pump casing.
  4. Medela Sonata Breast Pump Teardown: step 4, image 1 of 3 Medela Sonata Breast Pump Teardown: step 4, image 2 of 3 Medela Sonata Breast Pump Teardown: step 4, image 3 of 3
    • Remove the 3 T20 screws from black pump casing.
    • Carefully lift and remove black pump casing. There will still be one wire connecting to the main board.
    • Unplug connector on the main board, that attaches to the pump.
    • Unplug the 2 ribbon cables from the main board by sliding the tab out and removing the cable.
  5. Medela Sonata Breast Pump Teardown: step 5, image 1 of 1
    • The battery is attached to the black pump casing you just removed with adhesive.
  6. Medela Sonata Breast Pump Teardown: step 6, image 1 of 2 Medela Sonata Breast Pump Teardown: step 6, image 2 of 2
    • Remove the 6 T10 screws from the main board.
  7. Medela Sonata Breast Pump Teardown: step 7, image 1 of 2 Medela Sonata Breast Pump Teardown: step 7, image 2 of 2
    • Remove the main board and display panel.
    • To put pump back together, perform steps in reverse.
Colin Hearn
202 Reputation
1 Guide authored
One Comment
Where did you find a battery replacement?
Brandon St. Angelo - Reply
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 116
All Time: 3,707
