Video Overview
This teardown is not a repair guide. To repair your Microsoft Surface Pro 7, use our service manual.
    Final Thoughts
    • To the extent that screws are used, they are all standard Torx fasteners.
    • All repairs require first removing the display assembly—which is stubbornly glued in place, expensive, and prone to shattering.
    • The battery is also firmly glued in place, requiring tons of heat and prying or solvents to remove.
    • The RAM, SSD and CPU are all soldered to the motherboard. Replacing any of those components requires a full motherboard replacement.
    Repairability Score
    Repairability 1 out of 10
    (10 is easiest to repair)
16 Comments
that is disappointing. Had small camera issue and just received another device in Microsoft store as warranty case
Yakauleu Aliaksandr - Reply
lol this video is disappointing for sure
Tyler Salazar -
Hi, What is the bluetooth module on surfece pro 7?
John Ostrowski - Reply
It uses an Intel AX201 WiFi chipset, and the bluetooth module built into that.
Chris N -
I’m looking for a replacement touch screen connector for the Surface Pro 7 but i can only find the older model for the pro4 and pro5, could anyone point me in the right direction
James B - Reply
Past 24 Hours: 50
Past 7 Days: 257
Past 30 Days: 1,111
All Time: 89,464
