Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
This teardown is not a repair guide. To repair your Moto G4, use our service manual.
  1. Motorola Moto G4 Teardown, Motorola Moto G4 Teardown: step 1, image 1 of 2 Motorola Moto G4 Teardown, Motorola Moto G4 Teardown: step 1, image 2 of 2
    • Place your thumb in the indent located at bottom left corner of the back cover.
    • The cover will pop up and begin to lift.
    • Continue to slide your fingers up the sides to remove the back cover.
  2. Motorola Moto G4 Teardown: step 2, image 1 of 2 Motorola Moto G4 Teardown: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the gray plastic surrounding the camera lens.
    • There will be a lot of glue and you may have to pull hard on the plastic piece.
  3. Motorola Moto G4 Teardown: step 3, image 1 of 2 Motorola Moto G4 Teardown: step 3, image 2 of 2
    • With tweezers, slide under all sides of the lens to loosen it.
    • Pulls the lens towards you to remove the lens.
    • There will be glue under the lens. You may have to pull hard to remove the lens.
    • Do not pull too hard on the lens. Pulling hard on it can result in breaking the lens.
  4. Motorola Moto G4 Teardown: step 4, image 1 of 2 Motorola Moto G4 Teardown: step 4, image 2 of 2
    • Using the screwdriver equipped with the T4 head drill bit, begin unscrewing the screws on the back panel.
    • Keep the screws on a magnetic board or strip to not lose any of them.
    • After all the screws are removed from the back panel, lift the back panel off.
  5. Motorola Moto G4 Teardown: step 5, image 1 of 2 Motorola Moto G4 Teardown: step 5, image 2 of 2
    • Using the tweezers, unhook the twisted red and black wire from under the black plastic pieces that are holding it down.
    • Using the tweezers, disconnect the wire from its connective port.
    • Use the spudger to lift the battery out.
    • The battery is glued down so you will have to use some force to pull it out.
    • Be careful not to pull it too hard it could bend the battery.
  6. Motorola Moto G4 Teardown: step 6, image 1 of 3 Motorola Moto G4 Teardown: step 6, image 2 of 3 Motorola Moto G4 Teardown: step 6, image 3 of 3
    • Using the tweezers, slide them under the speaker and pull the speaker out.
    • The back of the speaker is magnetic. Be careful to not touch it t other parts of the motherboard.
  7. Motorola Moto G4 Teardown: step 7, image 1 of 3 Motorola Moto G4 Teardown: step 7, image 2 of 3 Motorola Moto G4 Teardown: step 7, image 3 of 3
    • Using the tweezers, pull up on the clasp that is holding the motherboard down.
    • Using the tweezers, pull up on the clasp that is connecting the motherboard to the front-facing camera.
    • Using the tweezers, remove the red and black wiring from the bottom of the phone by the charging port.
  8. Motorola Moto G4 Teardown: step 8, image 1 of 2 Motorola Moto G4 Teardown: step 8, image 2 of 2
    • Using the tweezers pull up on the three corners of the motherboard until it comes out.
Kierra Schau
1,511 Reputation
4 Guides authored
USF Tampa, Team S11-G2, Passmore Fall 2017 Member of USF Tampa, Team S11-G2, Passmore Fall 2017
USFT-PASSMORE-F17S11G2
3 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,181
