This teardown is not a repair guide. To repair your NeXTstation, use our service manual.
  1. NeXTstation Teardown, NeXTstation Teardown: step 1, image 1 of 3 NeXTstation Teardown, NeXTstation Teardown: step 1, image 2 of 3 NeXTstation Teardown, NeXTstation Teardown: step 1, image 3 of 3
    • The NeXTStation, this is a great addition to any computer collection.
  2. NeXTstation Teardown: step 2, image 1 of 3 NeXTstation Teardown: step 2, image 2 of 3 NeXTstation Teardown: step 2, image 3 of 3
    • Turn the NeXTStation around, and remove this screw:
    • Then, lift the top cover of the computer. This will reveal the guts.
    • The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
    • I find notes in everything!
  3. NeXTstation Teardown: step 3, image 1 of 2 NeXTstation Teardown: step 3, image 2 of 2
    • Removing the hard drive:
    • The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
    • Remove all of the cables from the logic board.
  4. NeXTstation Teardown: step 4, image 1 of 3 NeXTstation Teardown: step 4, image 2 of 3 NeXTstation Teardown: step 4, image 3 of 3
    • Then remove this screw.
    • Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
  5. NeXTstation Teardown: step 5, image 1 of 1
    • The Hard Drive & Caddy
  6. NeXTstation Teardown: step 6, image 1 of 3 NeXTstation Teardown: step 6, image 2 of 3 NeXTstation Teardown: step 6, image 3 of 3
    • Removing the floppy disk drive:
    • The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
    • Remove the floppy cable.
    • Then, remove this screw.
  7. NeXTstation Teardown: step 7, image 1 of 3 NeXTstation Teardown: step 7, image 2 of 3 NeXTstation Teardown: step 7, image 3 of 3
    • Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
  8. NeXTstation Teardown: step 8, image 1 of 3 NeXTstation Teardown: step 8, image 2 of 3 NeXTstation Teardown: step 8, image 3 of 3
    • Removing the fan:
    • Remove this connector.
    • Remove these screws.
    • Remove the fan.
  9. NeXTstation Teardown: step 9, image 1 of 3 NeXTstation Teardown: step 9, image 2 of 3 NeXTstation Teardown: step 9, image 3 of 3
    • Removing the logic board:
    • Remove the power supply connector. Just lift it straight up, and it should come free.
    • Remove this screw.
  10. NeXTstation Teardown: step 10, image 1 of 3 NeXTstation Teardown: step 10, image 2 of 3 NeXTstation Teardown: step 10, image 3 of 3
    • Lift the end of the logic board(away from the ports), and slide it away from the ports.
    • Now, set the board aside.
  11. NeXTstation Teardown: step 11, image 1 of 3 NeXTstation Teardown: step 11, image 2 of 3 NeXTstation Teardown: step 11, image 3 of 3
    • Power Supply:
    • Lift the power supply up, and out.
  12. NeXTstation Teardown: step 12, image 1 of 1
    • The Logic Board Overview:
    • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for something made nearly 20 years ago.
    • The CPU: Motorola XC68040RC25
    • The Co-Procesor: MB610313
    • Motorola Chips
    • Intel Chips
    • AMD Chips (Intel and AMD In the same computer?)
    • Fujitsu Chips
  13. NeXTstation Teardown: step 13, image 1 of 3 NeXTstation Teardown: step 13, image 2 of 3 NeXTstation Teardown: step 13, image 3 of 3
    • Made in the USA, you don't see this anymore.
    • The Serial #
    • Looks like my NeXTStation came from WilTel.
    • It is model # N1100
Chris Green
37,668 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,699 Guides authored
3 Comments
http://www.youtube.com/watch?v=jhfUKEu7s...
The Machine to Build the Machines:
Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Juddy - Reply
Quote from Juddy:
http://www.youtube.com/watch?v=jhfUKEu7s... The Machine to Build the Machines: Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Amazing!
Chris Green - Reply
MB610313 - ICP (Integrated Channel Processor). Basically DMA on steroids for almost all of the main sub components of the system. I believe that the cube, or at least the 25Mhz 030/040 cubes, had two of these.
HotelCoralEssex - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 83
All Time: 31,507
