This teardown is not a repair guide. To repair your Nokia N900, use our service manual.
  1. Nokia N900 Teardown, Nokia N900 Teardown: step 1, image 1 of 1
    • First, flip the phone so the back is facing upwards.
  2. Nokia N900 Teardown: step 2, image 1 of 1
    • Next, locate the slit on the side of the phone and remove the back cover.
  3. Nokia N900 Teardown: step 3, image 1 of 1
    • Once the back has been removed, take out the battery.
  4. Nokia N900 Teardown: step 4, image 1 of 1
    • Using a small bit screwdriver, unscrew all six screws located in the back of the phone. If necessary, iFixit has 16 to 112 Bit Driver kits available for purchase.
  5. Nokia N900 Teardown: step 5, image 1 of 2 Nokia N900 Teardown: step 5, image 2 of 2
    • Once all six screws have been removed, gently pull the phone apart. You should now be left with two pieces.
  6. Nokia N900 Teardown: step 6, image 1 of 2 Nokia N900 Teardown: step 6, image 2 of 2
    • Taking the back of the phone, remove the qwerty key mat. It should come off easily.
  7. Nokia N900 Teardown: step 7, image 1 of 3 Nokia N900 Teardown: step 7, image 2 of 3 Nokia N900 Teardown: step 7, image 3 of 3
    • Using the blue opening tool, pry out the green motherboard.
  8. Nokia N900 Teardown: step 8, image 1 of 2 Nokia N900 Teardown: step 8, image 2 of 2
    • Now, take the front half of the phone. Use the screwdriver to remove all six screws.
  9. Nokia N900 Teardown: step 9, image 1 of 1
    • Once pulled apart, you should be left with two pieces.
  10. Nokia N900 Teardown: step 10, image 1 of 2 Nokia N900 Teardown: step 10, image 2 of 2
    • With the touch screen now removed from the keyboard slider, use the blue, plastic opening tool to remove the cover of the screen.
    • It is highly advised to take off one side at a time.
    • Once one section of the cover has been removed, the second cover will be removable. You have officially completed tearing down a Nokia N900.
Juan Haro
284 Reputation
2 Guides authored
One Comment
Looks like the LCD flex cable ripped off on this teardown, ouch!
Leonard Putra - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 5,660
