This teardown is not a repair guide. To repair your Nintendo Wii Remote, use our service manual.
  1. Nyko Wand Teardown, Removing battery cover and back plate: step 1, image 1 of 3 Nyko Wand Teardown, Removing battery cover and back plate: step 1, image 2 of 3 Nyko Wand Teardown, Removing battery cover and back plate: step 1, image 3 of 3
    • First flip controller so that the back plate faces you
    • Remove the battery cover by pushing up on the bottom plate
  2. Nyko Wand Teardown: step 2, image 1 of 2 Nyko Wand Teardown: step 2, image 2 of 2
    • Remove both batteries if their are any inside the remote .
    • To remove them press down on the positive end then pull to take out
  3. Nyko Wand Teardown: step 3, image 1 of 2 Nyko Wand Teardown: step 3, image 2 of 2
    • Using the tri-point Y1 Screw driver remove the two center screws by turning counter clock wise
    • Repeat process for bottom two
  4. Nyko Wand Teardown: step 4, image 1 of 3 Nyko Wand Teardown: step 4, image 2 of 3 Nyko Wand Teardown: step 4, image 3 of 3
    • To fully take off the back piece you will have to use your flat head screw driver and gently go along the edge and unclip it.
    • Gently pull out the whole circuit board ( be careful you may break or rip a wire if you pull to hard )
    • {CAUTION :WATCH OUT FOR SMALL PARTS}
  5. Nyko Wand Teardown: step 5, image 1 of 3 Nyko Wand Teardown: step 5, image 2 of 3 Nyko Wand Teardown: step 5, image 3 of 3
    • To remove the buttons you will simply have to take off the grey silicon cover.
    • To remove the small speaker you can simply pull up .
    • CAUTION : FOR SMALLER BUTTONS LIKE THE VOLUME ONES .
  6. Nyko Wand Teardown: step 6, image 1 of 2 Nyko Wand Teardown: step 6, image 2 of 2
    • Gently pry the buttons upwards ,removing the buttons from its holding slot.
    • CAUTION : WATCH OUT FOR SMALL BUTTONS !
    • IF YOU WANT TO REBUILD IT FOLLOW STEPS 1-7 BACKWORDS.
Demian De La Vega
143 Reputation
1 Guide authored
One Comment
good¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 2,457
