Introduction
This guide will show you how to completely teardown your camera.
Locate the 2 screws on the bottom of the slider.
Remove both screws with a #00 Phillips screwdriver.
Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
Locate the gray compartment covering the flash.
Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
Gently lift the tab so the gray compartment becomes free.
