This teardown is not a repair guide. To repair your Pac-Man Connect and Play, use our service manual.
  1. Pac-Man Connect and Play Teardown, Pac-Man Connect and Play Teardown: step 1, image 1 of 2 Pac-Man Connect and Play Teardown, Pac-Man Connect and Play Teardown: step 1, image 2 of 2
    • I start by flipping over the device.
  2. Pac-Man Connect and Play Teardown: step 2, image 1 of 3 Pac-Man Connect and Play Teardown: step 2, image 2 of 3 Pac-Man Connect and Play Teardown: step 2, image 3 of 3
    • I remove 5 Phillips head screws for the case
    • And one more to remove the batteries
  3. Pac-Man Connect and Play Teardown: step 3, image 1 of 2 Pac-Man Connect and Play Teardown: step 3, image 2 of 2
    • Inside, all I see are glorious Phillips Head screws!
    • Finally! Something repairable!
    • Battery Compartment
    • Power Switch and LED board
    • Mainboard/Joystick board
    • A and B button board
  4. Pac-Man Connect and Play Teardown: step 4, image 1 of 2 Pac-Man Connect and Play Teardown: step 4, image 2 of 2
    • I start with the buttons.
  5. Pac-Man Connect and Play Teardown: step 5, image 1 of 1
    • They were very, very easy to get to and remove.
  6. Pac-Man Connect and Play Teardown: step 6, image 1 of 3 Pac-Man Connect and Play Teardown: step 6, image 2 of 3 Pac-Man Connect and Play Teardown: step 6, image 3 of 3
    • Now, for the mainboard.
    • 2 screws get me underneath.
    • But, what's this?
  7. Pac-Man Connect and Play Teardown: step 7, image 1 of 3 Pac-Man Connect and Play Teardown: step 7, image 2 of 3 Pac-Man Connect and Play Teardown: step 7, image 3 of 3
    • Another 4 screws, and POP! it is holding a spring down, for the joystick.
    • There did not appear to be an easy way to get the joystick out, however.
  8. Pac-Man Connect and Play Teardown: step 8, image 1 of 2 Pac-Man Connect and Play Teardown: step 8, image 2 of 2
    • Finally, I see a power regulator?
  9. Pac-Man Connect and Play Teardown: step 9, image 1 of 2 Pac-Man Connect and Play Teardown: step 9, image 2 of 2
    • Nope! It's just the power switch and LED.
  10. Pac-Man Connect and Play Teardown: step 10, image 1 of 1
    • Back Main PCB IC Identification:
    • You may need to enlarge it to view the text.
  11. Pac-Man Connect and Play Teardown, Conclusion: step 11, image 1 of 2 Pac-Man Connect and Play Teardown, Conclusion: step 11, image 2 of 2
    • In conclusion, I LOVE how it's all the J1 Phillips Head screw, throughout the entire device.
    • It's easy to get under every board.
    • There are, unfortunately, no plugs, and so everything is soldered on. This removes the possibility of replacing any electrical internals.
9021007
4,599 Reputation
25 Guides authored
2 Comments
It should not be too hard to replace stuff as long as you know how to solder. However many chips cannot be replaced as they are either epoxied on or need to be programmed before it would work in the device.
CChin - Reply
Can you help me?
I need repair this game and need the number of part of the integrated circuit number U15 this can find at side of the red an black wire in the principal board. In my board is absolutely Imposible read it is destroyed. Only can read the first number (4) and the last (2L)
PLEASE HELP ME!!
jonatan quintero - Reply
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 28
All Time: 1,820
