This teardown is not a repair guide. To repair your Pantech Crux, use our service manual.
  1. Pantech Crux Teardown, Pantech Crux Teardown: step 1, image 1 of 3 Pantech Crux Teardown, Pantech Crux Teardown: step 1, image 2 of 3 Pantech Crux Teardown, Pantech Crux Teardown: step 1, image 3 of 3
    • Let's see what's inside!
    • Turn your Pantech Crux so that the back cover is facing upwards.
    • Press the indented area at the top of the back cover with one thumb and slide down the cover with your other thumb.
    • Remove back cover and set it to the side.
  2. Pantech Crux Teardown: step 2, image 1 of 2 Pantech Crux Teardown: step 2, image 2 of 2
    • Place your thumbnail in the groove at the bottom of the battery.
    • Lift your thumbnail up to remove the battery from the battery casing.
  3. Pantech Crux Teardown: step 3, image 1 of 3 Pantech Crux Teardown: step 3, image 2 of 3 Pantech Crux Teardown: step 3, image 3 of 3
    • Grab something with a Phillips #000 Screwdriver head.
    • Locate the four screws on the corners of where the back cover was.
    • Use the Phillips #000 Screwdriver to remove these screws.
  4. Pantech Crux Teardown: step 4, image 1 of 2 Pantech Crux Teardown: step 4, image 2 of 2
    • Locate the two screw covers at the top of the phone.
    • Grab a 0.8 SIM Eject bit.
    • Use this bit to get underneath the cover and lift up.
    • Remove both covers.
    • Use the Phillips #000 Screwdriver to remove both screws.
  5. Pantech Crux Teardown: step 5, image 1 of 3 Pantech Crux Teardown: step 5, image 2 of 3 Pantech Crux Teardown: step 5, image 3 of 3
    • Flip your Pantech Crux so the screen is facing upwards.
    • Locate the sticker above your screen (it has a lock on it).
    • Use the 0.8 SIM Eject bit to get underneath the sticker.
    • Peel up the sticker.
    • Use a Phillips #000 Screwdriver to remove the screw that was beneath the sticker.
  6. Pantech Crux Teardown: step 6, image 1 of 3 Pantech Crux Teardown: step 6, image 2 of 3 Pantech Crux Teardown: step 6, image 3 of 3
    • Locate the area where the back case meets the silver outlining.
    • Use your thumb or the 0.8 SIM Eject bit to lift the back case up.
    • Slide either your thumb or the 0.8 SIM Eject bit between the back case and the silver outlining until the back case comes free.
    • Lift and remove the back case from the phone.
    • Place phone with the screen facing downwards.
  7. Pantech Crux Teardown: step 7, image 1 of 3 Pantech Crux Teardown: step 7, image 2 of 3 Pantech Crux Teardown: step 7, image 3 of 3
    • Locate the buttons on the side of the phone that are now loose.
    • Remove these buttons by pulling on them with your thumb and pointer finger.
  8. Pantech Crux Teardown: step 8, image 1 of 2 Pantech Crux Teardown: step 8, image 2 of 2
    • Locate the screw that is in the middle of the motherboard.
    • Use the Phillips #000 Screwdriver to remove this screw.
  9. Pantech Crux Teardown: step 9, image 1 of 1
    • Loosen the motherboard from the front case.
  10. Pantech Crux Teardown: step 10, image 1 of 1
    • Locate the small wire in the bottom right corner of the motherboard.
    • Release this wire by gently pulling up on it with your thumb and pointer finger.
  11. Pantech Crux Teardown: step 11, image 1 of 3 Pantech Crux Teardown: step 11, image 2 of 3 Pantech Crux Teardown: step 11, image 3 of 3
    • Lift the motherboard.
    • Locate the cable that attaches the motherboard to the front case.
    • Use the 0.8 SIM Eject bit or your nail to lift up and pop off the piece that attaches the cable to the motherboard.
  12. Pantech Crux Teardown: step 12, image 1 of 2 Pantech Crux Teardown: step 12, image 2 of 2
    • Flip the motherboard to the left of the front case.
    • Locate the four screws that were below the motherboard.
    • Use the Phillips #000 Screwdriver to remove all four screws.
  13. Pantech Crux Teardown: step 13, image 1 of 2 Pantech Crux Teardown: step 13, image 2 of 2
    • Use your thumb or the 0.8 SIM Eject bit to lift up the layer containing the motherboard from the front of the phone.
    • Run your thumb or the 0.8 SIM Eject bit along the edge of this layer to loosen it.
    • Remove the layer when it becomes loose enough.
  14. Pantech Crux Teardown: step 14, image 1 of 3 Pantech Crux Teardown: step 14, image 2 of 3 Pantech Crux Teardown: step 14, image 3 of 3
    • Underneath the layer you just removed is a piece of metal with seven screws on it.
    • Use a Phillips #000 Screwdriver to remove all seven screws.
    • Use your finger or the 0.8 SIM Eject bit to remove this metal piece from the front of the phone.
  15. Pantech Crux Teardown: step 15, image 1 of 2 Pantech Crux Teardown: step 15, image 2 of 2
    • What you see is the back of the screen.
    • To remove the screen lift it up from the side.
  16. Pantech Crux Teardown: step 16, image 1 of 1
    • Congratulations! You have completed a teardown of the Pantech Crux.
Megan Voss
79 Reputation
1 Guide authored
One Comment
Thanks for the help. It was fun to take apart my phone and see if I could fix it before trading in for a new one.
The screen is black: it shows light, but it is just projecting a black screen. Since this is a touch screen, that means that I can't see anything that I am doing or even make a phone call. I have memorized where the "answer" button is, so I can receive...
Thanks again!
BustoJuice - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,012
