This teardown is not a repair guide. To repair your Philips - Norelco RQ1280 SensoTouch 3D, use our service manual.
  1. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Introduction: step 1, image 1 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Introduction: step 1, image 2 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Introduction: step 1, image 3 of 3
    • Philips - Norelco RQ1280 SensoTouch 3D
  2. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Getting In: step 2, image 1 of 2 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Getting In: step 2, image 2 of 2
    • With no visible screws or clips, the only other method is to pry away at the seam.
    • The drain hole provided the necessary gap to insert the pick and begin prying.
  3. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Frame: step 3, image 1 of 2 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Frame: step 3, image 2 of 2
    • Once the pick is worked around the seam, the frame unclips.
    • There are 4 clips holding the frame to the shaver body.
    • The plastic clips are extremely fragile, due to them clipping onto metal tabs.
  4. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Top Case and Button: step 4, image 1 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Top Case and Button: step 4, image 2 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Top Case and Button: step 4, image 3 of 3
    • With the frame removed, the top case and button easily lift off.
  5. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Rear Case: step 5, image 1 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Rear Case: step 5, image 2 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Rear Case: step 5, image 3 of 3
    • The rear case is removed by gently squeezing the metal tabs away from the case.
    • The metal tabs act like compression springs to hold against the rear case.
    • The metal tabs mentioned in Step 3 are better visualised here.
  6. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Magnet: step 6, image 1 of 1
    • The small magnet on the rear serves to hold the shaver in place on both the charging dock and cleaning station.
    • The South pole of the magnet should face outwards.
  7. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Waterproof Enclosure: step 7, image 1 of 2 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Waterproof Enclosure: step 7, image 2 of 2
    • The main electronics are housed within a waterproof enclosure.
    • A series of 6 clips hold the enclosure together.
  8. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Reviving: step 8, image 1 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Reviving: step 8, image 2 of 3 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Reviving: step 8, image 3 of 3
    • The motor is easily disconnected with a single plug.
    • The board powers to life after holding the battery at 3.7V.
  9. Philips - Norelco RQ1280 SensoTouch 3D Teardown, Conclusion: step 9, image 1 of 2 Philips - Norelco RQ1280 SensoTouch 3D Teardown, Conclusion: step 9, image 2 of 2
    • Follow the steps in reverse to assemble the shaver.
Rushil Kisoon
628 Reputation
3 Guides authored
4 Comments
Does the battery need to soldered to be able to replace it?
fitnessx - Reply
Yes, the batteries have the solder tabs on them.
Rushil Kisoon -
Hi please help me javadshoaleh@gmail.com
shaparak rohe - Reply
What are the battery specifications of this Philip model? Volts and amperes hours?
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 991
