This teardown is not a repair guide. To repair your Picstart Plus Development Programmer, use our service manual.
  1. Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: step 1, image 1 of 3 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: step 1, image 2 of 3 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: step 1, image 3 of 3
    • Remove 4 Phillips screws located on the back side of the holding plate.
    • After the screws are removed, remove the case of the development programmer.
    • Carefully take out the circuit board with component side facing up. Put the case aside.
  2. Picstart Plus Development Programmer Teardown: step 2, image 1 of 2 Picstart Plus Development Programmer Teardown: step 2, image 2 of 2
    • Disconnect the microcontroller module from the main board using a spudger or a similar tool.
    • Set the microcontroller module aside.
  3. Picstart Plus Development Programmer Teardown: step 3, image 1 of 2 Picstart Plus Development Programmer Teardown: step 3, image 2 of 2
    • Flip over the mainboard so that the component side is facing down and remove the small Pan head screws that holds the cover of the IC holder
    • Remove the cover of the IC holder.
  4. Picstart Plus Development Programmer Teardown: step 4, image 1 of 2 Picstart Plus Development Programmer Teardown: step 4, image 2 of 2
    • Remove the IC holder lever along with the small metal plate that covers the lever.
    • Set the lever and the lever cover aside.
  5. Picstart Plus Development Programmer Teardown: step 5, image 1 of 1
    • Congratulations! You have completely dismantled the PICSTART Plus Development Programmer!
    • All the extracted components are shown in the picture.
Brad
656 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 24
All Time: 2,766
