This teardown is not a repair guide. To repair your PlayStation 3, use our service manual.
  1. PlayStation 3 Fat 4 USB Teardown, The console case: step 1, image 1 of 1
    • Inserir instruções aqui.
  2. PlayStation 3 Fat 4 USB Teardown, Remove the screws: step 2, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the screws: step 2, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the screws: step 2, image 3 of 3
  3. PlayStation 3 Fat 4 USB Teardown, Open the console: step 3, image 1 of 1
  4. PlayStation 3 Fat 4 USB Teardown, Remove the power supply: step 4, image 1 of 2 PlayStation 3 Fat 4 USB Teardown, Remove the power supply: step 4, image 2 of 2
  5. PlayStation 3 Fat 4 USB Teardown, The power supply board: step 5, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, The power supply board: step 5, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, The power supply board: step 5, image 3 of 3
  6. PlayStation 3 Fat 4 USB Teardown, Remove the bluray driver: step 6, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the bluray driver: step 6, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the bluray driver: step 6, image 3 of 3
    • Be very careful to do not break the data connector because it is very fragile.
  7. PlayStation 3 Fat 4 USB Teardown, Remove the SD card slot: step 7, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the SD card slot: step 7, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the SD card slot: step 7, image 3 of 3
  8. PlayStation 3 Fat 4 USB Teardown, Remove the bluethoot board: step 8, image 1 of 2 PlayStation 3 Fat 4 USB Teardown, Remove the bluethoot board: step 8, image 2 of 2
  9. PlayStation 3 Fat 4 USB Teardown, Remove the intire motherboard from the case: step 9, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the intire motherboard from the case: step 9, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the intire motherboard from the case: step 9, image 3 of 3
  10. PlayStation 3 Fat 4 USB Teardown, Remove the coller and mother board shield: step 10, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the coller and mother board shield: step 10, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, Remove the coller and mother board shield: step 10, image 3 of 3
  11. PlayStation 3 Fat 4 USB Teardown, The cooler specifications and ball bearing: step 11, image 1 of 2 PlayStation 3 Fat 4 USB Teardown, The cooler specifications and ball bearing: step 11, image 2 of 2
  12. PlayStation 3 Fat 4 USB Teardown, The gigantic and unefective cooler: step 12, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, The gigantic and unefective cooler: step 12, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, The gigantic and unefective cooler: step 12, image 3 of 3
  13. PlayStation 3 Fat 4 USB Teardown, The mother board: step 13, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, The mother board: step 13, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, The mother board: step 13, image 3 of 3
  14. PlayStation 3 Fat 4 USB Teardown, The processors: step 14, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, The processors: step 14, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, The processors: step 14, image 3 of 3
  15. PlayStation 3 Fat 4 USB Teardown, Some details: step 15, image 1 of 3 PlayStation 3 Fat 4 USB Teardown, Some details: step 15, image 2 of 3 PlayStation 3 Fat 4 USB Teardown, Some details: step 15, image 3 of 3
    • Bios battery
    • Power on and eject sensors
    • Main AC power conector and ground conector
  16. PlayStation 3 Fat 4 USB Teardown, Some details: step 16, image 1 of 2 PlayStation 3 Fat 4 USB Teardown, Some details: step 16, image 2 of 2
    • HD Slot
    • HD case screw
Vinicius Rodrigues Bellini
1,016 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 79
Past 30 Days: 282
All Time: 5,882
