This teardown is not a repair guide. To repair your Polaroid One-Step 600, use our service manual.
  1. Polaroid One-Step 600 Teardown, Polaroid One-Step 600 Teardown: step 1, image 1 of 3 Polaroid One-Step 600 Teardown, Polaroid One-Step 600 Teardown: step 1, image 2 of 3 Polaroid One-Step 600 Teardown, Polaroid One-Step 600 Teardown: step 1, image 3 of 3
    • Open the flash/lens compartment of the Polaroid camera to a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Teardown: step 2, image 1 of 3 Polaroid One-Step 600 Teardown: step 2, image 2 of 3 Polaroid One-Step 600 Teardown: step 2, image 3 of 3
    • Separate the flash section of the camera from the main body by unhooking the sides.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Teardown: step 3, image 1 of 1
    • Open the battery/ cartridge compartment fully.
  4. Polaroid One-Step 600 Teardown: step 4, image 1 of 3 Polaroid One-Step 600 Teardown: step 4, image 2 of 3 Polaroid One-Step 600 Teardown: step 4, image 3 of 3
    • Insert spudger in between face of camera and sides where the four tabs are located.
  5. Polaroid One-Step 600 Teardown: step 5, image 1 of 2 Polaroid One-Step 600 Teardown: step 5, image 2 of 2
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Teardown: step 6, image 1 of 2 Polaroid One-Step 600 Teardown: step 6, image 2 of 2
    • Remove the capture button if it did not pop out when you removed the face.
    • There are two pieces to the capture button and both should be removed.
  7. Polaroid One-Step 600 Teardown: step 7, image 1 of 3 Polaroid One-Step 600 Teardown: step 7, image 2 of 3 Polaroid One-Step 600 Teardown: step 7, image 3 of 3
    • To remove the back of the camera, you have to find the tabs located near the hinges of the battery and film compartment.
    • Using a screw driver, pry the tabs of the outer case away from the metal frame.
    • Once the tabs are removed slide the metal frame forward.
  8. Polaroid One-Step 600 Teardown: step 8, image 1 of 2 Polaroid One-Step 600 Teardown: step 8, image 2 of 2
    • Remove the battery and film compartment latch
    • Pull the metal frame away from the case.
    • The entire case will come off but the flash compartment will come with the insides of the camera.
  9. Polaroid One-Step 600 Teardown: step 9, image 1 of 1
    • Using a spudger, pop the battery and film cartridge hatch from its hinges.
    • The tabs are located at the bottom of the metal frame.
  10. Polaroid One-Step 600 Teardown: step 10, image 1 of 3 Polaroid One-Step 600 Teardown: step 10, image 2 of 3 Polaroid One-Step 600 Teardown: step 10, image 3 of 3
    • Remove the sight by lifting it straight up.
    • Follow the red wire from the flash compartment
    • Take the red wire off of the 2 hooks
    • Slide the uncovered wire end out of the small brass clip. Move wire away from camera.
  11. Polaroid One-Step 600 Teardown: step 11, image 1 of 3 Polaroid One-Step 600 Teardown: step 11, image 2 of 3 Polaroid One-Step 600 Teardown: step 11, image 3 of 3
    • Follow the black wire from flash bulb to the back of the case.
    • When you find the brass tab, pull it up. When the tab is free, remove the tab from the black wire.
  12. Polaroid One-Step 600 Teardown: step 12, image 1 of 3 Polaroid One-Step 600 Teardown: step 12, image 2 of 3 Polaroid One-Step 600 Teardown: step 12, image 3 of 3
    • Follow the metal band from the flash compartment to the brass tab.
    • Unhook the wire on the left of the brass tab.
    • Remove the metal band from behind the brass clip.
    • Set the now detached flash compartment to the side.
    • Pull the brass tab up and out like the first one and remove the uncovered wire.
  13. Polaroid One-Step 600 Teardown: step 13, image 1 of 3 Polaroid One-Step 600 Teardown: step 13, image 2 of 3 Polaroid One-Step 600 Teardown: step 13, image 3 of 3
    • Slide the brightness adjuster to right and off the camera.
    • Use the pointed end of the spudger to lift a small latch located next to the bottom of lenz plate
    • Then find the small latch located below the plastic bridge that is over the shutter mechanism
    • This latch is small and is hard to see but you just have to push it with the pointed end of the spudger to unlatch it.
  14. Polaroid One-Step 600 Teardown: step 14, image 1 of 2 Polaroid One-Step 600 Teardown: step 14, image 2 of 2
    • Using the pointed end of the spudger, pull the band wire out of the electric motor.
    • In the same manner as above, remove the band wire from the plastic extension.
  15. Polaroid One-Step 600 Teardown: step 15, image 1 of 2 Polaroid One-Step 600 Teardown: step 15, image 2 of 2
    • Rotate the lens plate up to unhook the plat from two tabs located at the top of the plate.
    • Remove the lens plate, flash compartment and wires from the camera.
  16. Polaroid One-Step 600 Teardown: step 16, image 1 of 3 Polaroid One-Step 600 Teardown: step 16, image 2 of 3 Polaroid One-Step 600 Teardown: step 16, image 3 of 3
    • Follow the uncovered wire around the side of the camera
    • Remove the metal spring tab next to the counter
    • Remove the brass tab by lifting the top piece over the notch and sliding back.
  17. Polaroid One-Step 600 Teardown: step 17, image 1 of 3 Polaroid One-Step 600 Teardown: step 17, image 2 of 3 Polaroid One-Step 600 Teardown: step 17, image 3 of 3
    • Locate the small brass tab with the uncovered wire running through it.
    • Remove the wire by sliding under the hooks.
    • then unhook the uncovered wire from the the final latch located on the top of the plastic extension.
  18. Polaroid One-Step 600 Teardown: step 18, image 1 of 2 Polaroid One-Step 600 Teardown: step 18, image 2 of 2
    • The cameras insides could now be in two major pieces.
    • The Pyramid and the lens plate
  19. Polaroid One-Step 600 Teardown: step 19, image 1 of 3 Polaroid One-Step 600 Teardown: step 19, image 2 of 3 Polaroid One-Step 600 Teardown: step 19, image 3 of 3
    • The top of the pyramid has cover that can be lifted off
    • Below is the mirror which is held in by a tab.
    • Lift the tab with the spudger and pop out the mirror.
    • If you intend to reassemble the camera make sure the mirror is completely clean without any spots or fingerprints because they will affect the quality of your pictures.
  20. Polaroid One-Step 600 Teardown: step 20, image 1 of 3 Polaroid One-Step 600 Teardown: step 20, image 2 of 3 Polaroid One-Step 600 Teardown: step 20, image 3 of 3
    • There are 4 tabs total that must be removed for the next step
    • The first is directly under the spring mounted at the back left of the camera
    • The next is located on the front of the plastic extension
    • The third tab is used to connect the metal frame to the outer plastic
  21. Polaroid One-Step 600 Teardown: step 21, image 1 of 2 Polaroid One-Step 600 Teardown: step 21, image 2 of 2
    • The final tab holds several spring loaded pieces together, these may pop out the moment the tab is released.
    • The final tab is located below the backside of the photo-counter dial.
    • The numbers will be right side up if you are looking in the right direction.
    • Once all four tabs are removed the plate pulls out from the slot in the rear.
  22. Polaroid One-Step 600 Teardown: step 22, image 1 of 3 Polaroid One-Step 600 Teardown: step 22, image 2 of 3 Polaroid One-Step 600 Teardown: step 22, image 3 of 3
    • Lift the large gear away from its pin
    • The next piece is loaded with a small spring.
    • Carefully lift the "Y" shaped plastic piece from its pin and pull the spring from the pin as it is removed.
  23. Polaroid One-Step 600 Teardown: step 23, image 1 of 2 Polaroid One-Step 600 Teardown: step 23, image 2 of 2
    • Remove the Spring attached to the photo-counter dial.
    • Lift the photo-counter Dial off of its pin.
  24. Polaroid One-Step 600 Teardown: step 24, image 1 of 2 Polaroid One-Step 600 Teardown: step 24, image 2 of 2
    • Remove the spring attached to the film eject metal slide.
    • Remove the film eject metal slide
  25. Polaroid One-Step 600 Teardown: step 25, image 1 of 1
    • Remove the plastic extension by pulling it from the slot in the rear of the camera.
  26. Polaroid One-Step 600 Teardown: step 26, image 1 of 2 Polaroid One-Step 600 Teardown: step 26, image 2 of 2
    • Remove the metal gear from the gear set.
    • Pull the "L" shaped black plastic piece off of its pin.
  27. Polaroid One-Step 600 Teardown: step 27, image 1 of 2 Polaroid One-Step 600 Teardown: step 27, image 2 of 2
    • There are four gears to remove.
    • The gear on the left goes first, followed by the the right.
    • The right gear has a small leaf spring between it and the gear below it.
    • Then remove the black gear and then the last white gear.
  28. Polaroid One-Step 600 Teardown: step 28, image 1 of 3 Polaroid One-Step 600 Teardown: step 28, image 2 of 3 Polaroid One-Step 600 Teardown: step 28, image 3 of 3
    • Using the pointed end of the spudger, press the clip that is beneath all the gears next to the electric motor gear.
    • Lift the plastic box containing several long metal tabs
    • Then slide the box out.
  29. Polaroid One-Step 600 Teardown: step 29, image 1 of 1
    • Pull the electric motor straight out of the plastic piece.
  30. Polaroid One-Step 600 Teardown: step 30, image 1 of 3 Polaroid One-Step 600 Teardown: step 30, image 2 of 3 Polaroid One-Step 600 Teardown: step 30, image 3 of 3
    • Remove the spring located in the middle of the plastic mechanism.
    • Remove the two loose plastic pieces.
  31. Polaroid One-Step 600 Teardown: step 31, image 1 of 1
    • To remove the metal frame, press the two tabs with the spudger and slide it forward.
  32. Polaroid One-Step 600 Teardown: step 32, image 1 of 2 Polaroid One-Step 600 Teardown: step 32, image 2 of 2
    • With the point of the spudger, remove the band wire from the solenoid.
    • Remove the small LED from its clip, and then lift the flat wire array and the flash compartment away from the back of the lens plate.
  33. Polaroid One-Step 600 Teardown: step 33, image 1 of 1
    • Remove the solenoid from the back of the lens plate by removing the two tabs.
  34. Polaroid One-Step 600 Teardown: step 34, image 1 of 2 Polaroid One-Step 600 Teardown: step 34, image 2 of 2
    • Remove the lens by pressing the tab.
    • CAUTION: The lens may pop out when the tab is released.
    • Remove the back of the lens plate by unhooking the three clips that hold it together.
    • CAUTION: The Shutter leaves may fall out during this step.
  35. Polaroid One-Step 600 Teardown: step 35, image 1 of 2 Polaroid One-Step 600 Teardown: step 35, image 2 of 2
    • Remove the spring on the plastic bridge that attaches to the shutter mechanism
    • Remove the Shutter mechanism from the back of the lens plate.
  36. Polaroid One-Step 600 Teardown: step 36, image 1 of 3 Polaroid One-Step 600 Teardown: step 36, image 2 of 3 Polaroid One-Step 600 Teardown: step 36, image 3 of 3
    • Remove the Clear dial by unhooking the tab at the bottom of the dial
    • Lift the light blue piece out of the mechanism.
    • Lift the black piece out of the plastic plate.
  37. Polaroid One-Step 600 Teardown: step 37, image 1 of 1
    • Remove the clear green prism from the plastic plate.
  38. Polaroid One-Step 600 Teardown: step 38, image 1 of 1
    • The disassembled camera.
Adriano Agostino
50 Reputation
1 Guide authored
Cal Poly, Team 16-31, Maness Winter 2010 Member of Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Members
6 Guides authored
10 Comments
Is it possible to remove and change the camera straps for this camera?
stylencreate - Reply
Yes, after step 8 you will have the back case free then in the inside you will see the latches of the plastic plate that holds the strap, pry them carefully are 6, 2 on each side and 2 in the middle, in the middle of doing it myself have stopped since was no need for that so cannot tell you more.
eportillo5000 - Reply
Show me how to teardown the flash plz
RAW Fish - Reply
RAW Fish: Get a terminal driver or other thin device, and wedge it where you can see a line between the outer casing and front panel (where it says “Polaroid” with the rainbow logo). This will need a bit of brute force, but you will be able to seperate a right-angle of outer casing, from the back of the flash, and another right angled bit full of electrics and the front panel. DO NOT touch any of this electrical gubbins - discharging the capacitor through your fingers will HURT. From here you can take out the circuit board and do with it what you wish.
Ariane N -
Hi ! Thanks for your article ! I just bought a Barbie polaroid 600 ;) but unfortunately the flat wire between the camera the flash is disconnected (it dangles from the camera). I managed to remove the flash, that is no longer connected. Do you know how can I open the flash part to reconnect the wires ? Thanks ;)
Marie Dodue - Reply
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 289
All Time: 58,830
