Teardown
This teardown is not a repair guide. To repair your NES Cartridge, use our service manual.
Flip the cartridge face-down on your table.
Use a 3.8 mm gamebit screwdriver to undo the 3 screws on the rear of the cartridge, and set them aside.
Gently lift up the half of the cartridge facing up, and set it aside.
Gently lift out the PCB, and clean the pins with isopropyl alcohol and a cotton swab. if the pins still remain dirty, carefully sand the pins with a very fine-grit sandpaper.
with 3 other contributors
109 Reputation
1 Guide authored
Badges: 0
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 65
All Time: 1,275
