Introduction
The RadioShack 22-510 Switching Power Supply provides AC to DC conversion to mimic a car’s electrical system. This teardown looks at some of the components that make this supply function.
Removing the eight cover screws on either side of the power supply allows the cover to lift off
A fuse protects the system from overcurrent conditions and the chassis is grounded to protect the user from shorts to the case.
The fan connector pulls out by hand. The spade terminal connectors may require coaxing with a pair of pliers.
The Sunon MagLev KDE1205PFV2 runs at 4300 RPM for a maximum airflow of 13 CFM. A dirty fan might not meet these specifications. Remember to clean your fans!
The illuminated switch is connected by two sets of black and white AC wires and held in by two locking tabs.
Removing the heatsink from the spreader reveals the liberal use of thermal paste. Try not to get it on your hands, it's tough to wash off!
The silver heat spreader is screwed to the chassis and must be detached before removing the board.
The board lifts out of the chassis after removing the five screws holding it down.
The UC3842BN PWM controller handles the switching feedback.
The chassis has a sheet of plastic for short circuit prevention under the board.
A thermally conductive pad lies under the heatsink assembly for additional cooling capability.
