This teardown is not a repair guide. To repair your Ratchet, use our service manual.
  1. Ratchet Teardown, Duralast Ratchet Teardown: step 1, image 1 of 1
    • Complete ratchet
  2. Ratchet Teardown, Removing the flexible head: step 2, image 1 of 1
    • The head is attached with a machine screw and a split washer to make the head hold its position.
    • If the head slips sometimes the helical split washer can be bent out or replaced.
  3. Ratchet Teardown, Removing the ratcheting mechanism: step 3, image 1 of 2 Ratchet Teardown, Removing the ratcheting mechanism: step 3, image 2 of 2
    • Head opened and in pieces
  4. Ratchet Teardown, Ratcheting Mechanism: step 4, image 1 of 3 Ratchet Teardown, Ratcheting Mechanism: step 4, image 2 of 3 Ratchet Teardown, Ratcheting Mechanism: step 4, image 3 of 3
    • Ratcheting mechanism in various views
  5. Ratchet Teardown, Ratchet Mechanism Parts: step 5, image 1 of 1
    • Spring: holds ball bearing against pawl
    • Ball bearing: holds pawl in its position
    • Pawl: allows gear/tang to rotate in only one direction
    • Gear/Tang: part that rotates
    • Lever: selects the pawls position and what direction the gear turns
  6. Ratchet Teardown, Complete Ratchet: step 6, image 1 of 1
    • All parts laid out
Wieli
1,707 Reputation
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 38
All Time: 648
