This teardown is not a repair guide. To repair your redragon m686, use our service manual.
  1. Redragon m686 Teardown, Redragon m686 Teardown: step 1, image 1 of 3 Redragon m686 Teardown, Redragon m686 Teardown: step 1, image 2 of 3 Redragon m686 Teardown, Redragon m686 Teardown: step 1, image 3 of 3
    • You need to remove the pads and unscrew the five hidden screws. after that, there is a pesky clip (shown in the blue circle)
  2. Redragon m686 Teardown: step 2, image 1 of 2 Redragon m686 Teardown: step 2, image 2 of 2
    • After you survive that clip, open the shell like a book and carefully unplug the cable connecting the halves.
  3. Redragon m686 Teardown: step 3, image 1 of 1
    • If you managed not to break them, take out the screws in the top.
    • I used the J1 bit and used a lot of force because that was the bit I had that fit the best and that wouldn't strip it. You can use whatever you like but be cautions of it stripping!
  4. Redragon m686 Teardown: step 4, image 1 of 3 Redragon m686 Teardown: step 4, image 2 of 3 Redragon m686 Teardown: step 4, image 3 of 3
    • On the bottom part, you just have to take out the screw by the mouse wheel to take the rest out.
Eclipse Nox
469 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 67
All Time: 172
