This teardown is not a repair guide. To repair your Roborock Q Revo, use our service manual.
  1. Roborock Q Revo: Teardown, Remove the dustbin.: step 1, image 1 of 3 Roborock Q Revo: Teardown, Remove the dustbin.: step 1, image 2 of 3 Roborock Q Revo: Teardown, Remove the dustbin.: step 1, image 3 of 3
    • Open the back.
    • Remove the dustbin.
  2. Roborock Q Revo: Teardown, Remove the rubber cap covering a screw.: step 2, image 1 of 3 Roborock Q Revo: Teardown, Remove the rubber cap covering a screw.: step 2, image 2 of 3 Roborock Q Revo: Teardown, Remove the rubber cap covering a screw.: step 2, image 3 of 3
    • This rubber cap has a layer of adhesive and is stuck to the screw. The adhesive doesn't hold it in place firmly.
    • Remove the cap, then save it somewhere. It's purely cosmetic, so don't worry too much if you do lose it.
    • Once you remove the cap, remove the screw using a PH2 screwdriver.
  3. Roborock Q Revo: Teardown, Remove the bottom cover.: step 3, image 1 of 1
    • Flip it over.
    • I use some padding underneath to prevent it sitting solely on the LDS cage.
    • Remove the side brush using a PH2 screwdriver.
    • Remove the marked screws using a PH2 screwdriver.
  4. Roborock Q Revo: Teardown, Remove the battery.: step 4, image 1 of 3 Roborock Q Revo: Teardown, Remove the battery.: step 4, image 2 of 3 Roborock Q Revo: Teardown, Remove the battery.: step 4, image 3 of 3
    • Remove the battery by lifting the left side until you can reach the connector, then disconnecting the connector by squeezing it's release tab.
    • Do not just yank the battery out. You will tear the connector off the motherboard.
  5. Roborock Q Revo: Teardown, Remove the bumper.: step 5, image 1 of 2 Roborock Q Revo: Teardown, Remove the bumper.: step 5, image 2 of 2
    • Remove the screws using a PH1 screwdriver.
    • Lift the bumper's lid off.
  6. Roborock Q Revo: Teardown, Remove the bumper.: step 6, image 1 of 2 Roborock Q Revo: Teardown, Remove the bumper.: step 6, image 2 of 2
    • Flip the robot over.
    • Remove the bumper by tilting it forwards to get it off the little tabs on the front.
  7. Roborock Q Revo: Teardown, Remove the side brush motor.: step 7, image 1 of 1
    • Unscrew the screws using a PH2 screwdriver.
    • Simply lift it out.
  8. Roborock Q Revo: Teardown, Open it up!: step 8, image 1 of 3 Roborock Q Revo: Teardown, Open it up!: step 8, image 2 of 3 Roborock Q Revo: Teardown, Open it up!: step 8, image 3 of 3
    • Remove the remaining screws that hold the chassis together. Use a PH2 screwdriver.
    • Flip it over, then pull it apart.
  9. Roborock Q Revo: Teardown, Screeeews.: step 9, image 1 of 1
    • Screws organised by type and steps used in.
    • Use this during reassembly if needed.
DegenFixer
4,477 Reputation
24 Guides authored
10 Comments
Hello,
I am contacting you regarding a persistent issue with my Roborock QRevo
For some time now, my device has been regularly showing "error 13"
When the robot connects to the charging station, it stays there for about 3-5 minutes before disconnecting on its own. It then attempts to reconnect several times, entering and exiting the station repeatedly, until an error 13 appears
Each time it docks, the device indicates "charging in progress," but after a few minutes, the problem reoccurs.
Actions taken so far:
I have thoroughly cleaned the charging contacts on both the robot and the station using a specific electrical contact cleaner.
I measured the voltage of the charging station terminals: it reads 4.15 volts.
I measured the battery voltage of the robot: it reads 14.7 volts.
After a full night of complete shutdown, the robot attempted to charge again, but only gained 1 to 2% battery after 10 minutes before disconnecting
Could you please advise on the next steps to resolve this problem?
aymeric.denis@hotmail.fr - Reply
Error code 13 is a fault of the mainboard. This is pretty common on this robots. There is no other fix than to change the mainboard
joel hil -
In my experience, error 13 (Charging error) is caused by one of 4 things. Robot's motherboard, Robot's battery, dock's motherboard or the dock's PSU.
The robot's motherboard is one possibility, but it is not the only one.
DegenFixer -
This is so good, there is a suction filter on the dock, inside the dust bag compartment. Is it easy to remove and clean? I have not found the way to do it, and when the suction from the mobile vacuum takes place, any smell in the bag vents out/impregnates that filter or ducts apparently.
Any help would be appreciated
seaoftranquility - Reply
Not sure which filter you mean, but if you mean the circular filter in the dust bag compartment, you just twist it off and clean it using a brush.
DegenFixer -
Past 24 Hours: 39
Past 7 Days: 257
Past 30 Days: 1,039
All Time: 5,067
