Introduction
Here is a relatively inexpensive and small guitar amp. This particular one needed some repair. So while I was waiting for parts, I figured I might as well make a teardown.
Here is the front view of the Rogue G10 amp.
Back side shows 4 Phillips head screws that need to be removed.
Here are the 4 #6x1" screws
This shows the corners with the screws removed.
Remove the rubber feet by removing the Phillips head screws.
On the left and right side of the amp is a Phillips head screw, located 1/3 down from the top and to the front. These two screws hold the front panel to which the speaker is attached. Remove those.
4 Comments
Do these models have tubes in them?
No, they do not. Strictly solid state
Thank you so much
