This teardown is not a repair guide. To repair your Samsung Galaxy Centura, use our service manual.
  1. Samsung Galaxy Centura Teardown, Samsung Galaxy Centura Teardown: step 1, image 1 of 2 Samsung Galaxy Centura Teardown, Samsung Galaxy Centura Teardown: step 1, image 2 of 2
    • This is the Samsung Galaxy Centura, a low-end smartphone made for the Tracfone/Straight Talk networks.
  2. Samsung Galaxy Centura Teardown: step 2, image 1 of 2 Samsung Galaxy Centura Teardown: step 2, image 2 of 2
    • Remove the battery, and then remove the 7 Phillips screws surrounding the outer casing.
  3. Samsung Galaxy Centura Teardown: step 3, image 1 of 3 Samsung Galaxy Centura Teardown: step 3, image 2 of 3 Samsung Galaxy Centura Teardown: step 3, image 3 of 3
    • Pop the 4 clips on both the left and right side of the phone. The outer casing should come right off by pulling.
    • This antenna can be removed with a spudger or screwdriver.
    • This is the speaker assembly (with more antennas!)
  4. Samsung Galaxy Centura Teardown: step 4, image 1 of 3 Samsung Galaxy Centura Teardown: step 4, image 2 of 3 Samsung Galaxy Centura Teardown: step 4, image 3 of 3
    • Disconnect the two flex cables with a spudger or plastic opening tool.
  5. Samsung Galaxy Centura Teardown: step 5, image 1 of 1
    • Now the display assembly is free.
  6. Samsung Galaxy Centura Teardown: step 6, image 1 of 1
    • Remove the 3 Phillips screws on the back of the motherboard to remove the EMI shielding.
  7. Samsung Galaxy Centura Teardown: step 7, image 1 of 1
    • Congrats! You've torn down the Samsung Galaxy Centura.
Brooks Robinson
127 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,418
