This teardown is not a repair guide. To repair your Samsung Galaxy Note 3, use our service manual.
  1. Samsung Galaxy Note 3 Teardown, Samsung Galaxy Note 3 Teardown: step 1, image 1 of 1
    • Turn the device off and use your finger to remove the back cover and battery. The Galaxy Note 3 battery is removable, making it easy to remove it without any tool.
  2. Samsung Galaxy Note 3 Teardown: step 2, image 1 of 2 Samsung Galaxy Note 3 Teardown: step 2, image 2 of 2
    • The back chassis is fastened by twelve Philips screws, so we have to undo the screws with the Philips screwdrivers.
  3. Samsung Galaxy Note 3 Teardown: step 3, image 1 of 3 Samsung Galaxy Note 3 Teardown: step 3, image 2 of 3 Samsung Galaxy Note 3 Teardown: step 3, image 3 of 3
    • Pull out the S pen and use spudger to release the back chassis. Then the chassis is separated from the rest of the device.
  4. Samsung Galaxy Note 3 Teardown: step 4, image 1 of 3 Samsung Galaxy Note 3 Teardown: step 4, image 2 of 3 Samsung Galaxy Note 3 Teardown: step 4, image 3 of 3
    • Disconnect seven cable connectors to remove the mainboard. Then the board is free.
  5. Samsung Galaxy Note 3 Teardown: step 5, image 1 of 2 Samsung Galaxy Note 3 Teardown: step 5, image 2 of 2
    • Take out the rear camera on the board.
  6. Samsung Galaxy Note 3 Teardown: step 6, image 1 of 2 Samsung Galaxy Note 3 Teardown: step 6, image 2 of 2
    • Use plastic case to release the antenna cable clips and remove the antenna cable.
  7. Samsung Galaxy Note 3 Teardown: step 7, image 1 of 2 Samsung Galaxy Note 3 Teardown: step 7, image 2 of 2
    • Use spudger to remove the USB board with proper strength because the USB board is stuck with glue.
  8. Samsung Galaxy Note 3 Teardown: step 8, image 1 of 2 Samsung Galaxy Note 3 Teardown: step 8, image 2 of 2
    • Undo the screw used to fasten the earphone jack and earphone and remove them.
  9. Samsung Galaxy Note 3 Teardown: step 9, image 1 of 2 Samsung Galaxy Note 3 Teardown: step 9, image 2 of 2
    • Remove the small metal bracket covering the front facing camera and sensor cable. Then remove the front camera and sensor cable.
  10. Samsung Galaxy Note 3 Teardown: step 10, image 1 of 2 Samsung Galaxy Note 3 Teardown: step 10, image 2 of 2
    • Use screwdriver to pry out the vibrating motor. Please be noted the motor is adhered to the front chassis and connected with the power button. Please lift it up carefully to avoid damaging the power button cable.
  11. Samsung Galaxy Note 3 Teardown: step 11, image 1 of 1
    • The Samsung Galaxy Note 3 teardown is complete.
matthew
3,435 Reputation
1 Guide authored
40 Comments
is it possible to use a Sprint Galaxy Note 3 USB port on a T-Mobile Galaxy Note 3?
Michael Paredes - Reply
It will fit, but the antenna are different. The phone will not work properly: the wireless reception will be worse.
Charles Hart -
I did exactly that and I haven't noticed any difference at all. My phone works and charges perfectly now, and all it took was 12 bucks and a little patience. Good luck!
Elizabeth Day -
I have a T-Mobile note 3 but can I use a sprint housing and lcd
john - Reply
If single sim it same
Hazrat Ishraaf -
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 88
All Time: 229,268
