Introduction
Go to step 1
Samsung just penned the death of the headphone jack with its newest phablet, the everything-but-the-kitchen-sink Galaxy Note10+ 5G. What else lies within that monolithic slab? In this teardown adventure, we breach its water-resistant seals, dredge its depths in search of elusive 5G chips, and encounter some surprising hardware along the way.
Stay tuned for new adventures by following us on TwitterInstagram, and Facebook. For iFixit delivered, check out our newsletter.
Tools
Show more…
iFixit earns commission when you buy through these links.
This teardown is not a repair guide. To repair your Samsung Galaxy Note10 Plus 5G, use our service manual.
  1. Samsung Galaxy Note10+ 5G Teardown, Samsung Galaxy Note10+ 5G Teardown: step 1, image 1 of 1
    • Before we tear down, we take Note of these 10+ 5G specs:
    • 6.8" AMOLED Infinity-O display with 3040 × 1440 resolution (498 ppi), HDR10+ certified
    • Qualcomm Snapdragon 855 paired with 12 GB RAM and 256 GB internal storage
    • 4,300 mAh battery
    • Four rear-facing cameras (16 MP ultra-wide, 12 MP wide-angle with OIS, 12 MP telephoto with OIS, VGA DepthVision camera), plus a 10 MP selfie cam
    • Ultrasonic in-screen fingerprint sensor
    • S Pen stylus with Bluetooth connectivity and 6-axis sensor
    • IP68 dust and water resistance rating
  2. Samsung Galaxy Note10+ 5G Teardown: step 2, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 2, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 2, image 3 of 3
    • We lay out (from left to right) last year's Note9 next to the new Note10+ and Note10+ 5G and try to spot the differences.
    • This year Samsung realigned the Note's cameras vertically. They also got rid of the rear fingerprint sensor—that's been moved under the display, like what we saw earlier this year.
    • At last, we're forced to mourn the loss of the headphone jack—supposedly a necessary tradeoff for a larger battery and improved haptic feedback.
    • It seems that Samsung, one of the last remaining Rebel allies, has decided to join the dark side.
    • Before we get any further, Creative Electron gives us a peek at some interesting internals—looks like we've got some fun exploration ahead.
  3. Samsung Galaxy Note10+ 5G Teardown: step 3, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 3, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 3, image 3 of 3
    • Out comes the star of this show: the magic wand new and improved S Pen.
    • Now with gesture control, for wizard-like wireless control of your Note10.
    • Cameras on all the newest Notes are vertically aligned, but the 10+ includes a fancy new feature alongside that stack of sensors.
    • Samsung's DepthVision time-of-flight sensor—exclusive to the largest Note10—uses an infrared illuminator and VGA camera to quickly and accurately measure distance. This sensor enables or enhances many of the Note's features, including Live focus, AR effects, and 3D object scanning.
    There is space for a pen, but not a headphone jack?
    LOL!
    Patrik Floding - Reply
  4. Samsung Galaxy Note10+ 5G Teardown: step 4, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 4, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 4, image 3 of 3
    Tool used on this step:
    iFixit Opening Picks (Set of 6)
    • Annnnd we're off! The delightful duo Heat and Pick get under the back cover without breaking a sweat (although the same may not be said for their wielders). It's almost like they do this every day.
    • This is standard procedure for most modern, glue-laden smartphones, but we sure wish that wasn't the case.
    • As we slice away at the adhesive, we notice that, this year, the cover is contoured around the volume and Bixby power buttons—not quite the change to the opening procedure we hoped for.
    Does the replacing of power button have an effect on the waterproofing of the phone!?
    sanjaya.sana - Reply
  5. Samsung Galaxy Note10+ 5G Teardown: step 5, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 5, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 5, image 3 of 3
    Mako Driver Kit - 64 Precision Bits
    $39.95
    • A few Phillips screws hold down the midframe assembly—nothing our tried-and-true Mako 64 bit kit can't handle!
    • With the midframe removed, we encounter a somewhat radical change: the motherboard is solely at the top of the device, Pixel-style.
    • While this allows for a wider battery, it makes the connection between mother and daughterboard trickier, necessitating these annoying interconnect cables that block battery access.
    • At least the cables are on top, rather than under a battery and primed for pry damage. So far, Apple's interlocking "L" shapes seem to be the best use of space we've seen...
  6. Samsung Galaxy Note10+ 5G Teardown: step 6, image 1 of 2 Samsung Galaxy Note10+ 5G Teardown: step 6, image 2 of 2
    iSclack
    $24.99
    • Our trusty iSclack works so well on heavily-glued displays that we decide to try it on this glued-down battery.
    • The iSclack gives us some solid leverage on the battery, but it still takes a lot of isopropyl alcohol—and even more patience—before the adhesive surrenders the battery (beware those display cables!).
    • If we called the Note9's 15.4 Wh battery "ludicrous," the Note 10+'s 16.56 Wh powerhouse must be "plaid."
    • This energy bar weighs in at 59.1 g and measures 77.3 mm x 58.4 mm x 5.5 mm. That's 4.4 g heavier and 3 cm³ larger than the Note9's battery.
  7. Samsung Galaxy Note10+ 5G Teardown: step 7, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 7, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 7, image 3 of 3
    • We jettison the SIM + microSD tray—a luxury that the smaller 6.3" Note10 has traded away—and release the motherboard.
    • Along for the ride are this Note's five cameras:
    • 16 MP ultra-wide (123° FoV)
    • 12 MP wide-angle with dual aperture (ƒ/1.5-ƒ/2.4)
    • 12 MP telephoto (2x optical zoom)
    • DepthVision time-of-flight infrared illuminator and sensor
    • 10 MP selfie cam
  8. Samsung Galaxy Note10+ 5G Teardown: step 8, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 8, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 8, image 3 of 3
    Hot Air Rework Station Hakko FR-810B-05
    $919.99
    • Although relieved of its many cameras, this board still feels like it's carrying some extra weight.
    • We pry off this mysterious green rectangle—which turns out to be a Qualcomm QTM052 mmWave antenna module.
    • "Millimeter wave" refers to RF signals with wavelengths measured in millimeters (24 GHz to 100 GHz). It offers super-duper fast download speeds, but can't travel long distances or penetrate walls very well. TL;DR: YMMV.
    • And one more thing: more board! Looks like Samsung took a note out of Apple's playbook and stacked their motherboard for maximum space savings.
    • We've been down this road before—and with a little help from our hot air station, we quickly carve through the vias and separate the boards.
    I did not realize that you guys were fanboys. Stacked boards are not new but of course Apple invented them. Disappointed..
    Peter Gordon - Reply
    Is it possible to reassemble the motherboard after separating the 2 layers?
    Farhan Mahmood - Reply
  9. Samsung Galaxy Note10+ 5G Teardown: step 9, image 1 of 2 Samsung Galaxy Note10+ 5G Teardown: step 9, image 2 of 2
    • Let's open this silicon sandwich and see what lies inside:
    • 12 GB Samsung K3UHAHADAM-AGCL LPDDR4X RAM layered over Qualcomm Snapdragon 855 SoC
    • 256 GB Samsung KLUEG8UHDB-C2D1 eUFS 3.0 flash storage
    • Qualcomm SDX50M 5G modem
    • NXP PN80T NFC controller w/ Secure Element
    • ON Semiconductor NCP59744 voltage regulator
    • Cirrus Logic CS35L40 audio amplifiers
    • Maxim MAX77705C PMIC
    Does the microSD slot have UHS-II pins? Snapdragon 855 includes support for it via the UFS 3.0 spec
    Future Zen - Reply
  10. Samsung Galaxy Note10+ 5G Teardown: step 10, image 1 of 2 Samsung Galaxy Note10+ 5G Teardown: step 10, image 2 of 2
    • Even more silicon filling:
    • Avago AFEM-9106 front end module
    • Skyworks SKY78160-51 low noise amplifier
    • Qualcomm SDR8150 LTE RF transceiver
    • WACOM W9020 digitizer controller (likely)
    • IDT P9320S wireless power receiver
    • Qualcomm QET5100 envelope tracker
    • Skyworks SKY77365-11 power amplifier module
  11. Samsung Galaxy Note10+ 5G Teardown: step 11, image 1 of 2 Samsung Galaxy Note10+ 5G Teardown: step 11, image 2 of 2
    • And just a little more:
    • Murata KM9515099 Wi-Fi/Bluetooth module
    • Qualcomm QDM3870 LTE RF front end module
    • Skyworks SKY13716-11 front-end module
    • Qualcomm WCD9341 Aqstic audio codec
    • Qualcomm PMX50 PMIC for the X50 modem
    • Qualcomm PM8150, PM8150C, and PM8005 (likely PMICs)
    • Samsung S2DOS05 display power management
  12. Samsung Galaxy Note10+ 5G Teardown: step 12, image 1 of 2 Samsung Galaxy Note10+ 5G Teardown: step 12, image 2 of 2
    • IC Identification part 4 courtesy of user Chunglin Chin:
    • Cirrus Logic CS40L25 haptic driver
    • STMicroelectronics STM32G071EB 32-Bit ARM Cortex-M0 microcontroller w/ 128 Kb flash
    • Samsung S2MIS0A MST driver
    • Qorvo QM78042 power amplifier module
    • Samsung S2MPB02 camera power management
    • Vishay DG2730 2-Port USB 2.0 DPDT analog switch
    • NXP Semiconductor BGU8103 GPS/GLONASS/Galileo/COMPASS low noise amplifier
  13. Samsung Galaxy Note10+ 5G Teardown: step 13, image 1 of 2 Samsung Galaxy Note10+ 5G Teardown: step 13, image 2 of 2
    • Sensor ID:
    • STMicroelectronics LSM6DSO 3 DoF accelerometer/gyroscope
    • STMicroelectronics LPS22HD pressure sensor
    • AKM Semiconductor AK0991x electronic compass
    • AMS proximity sensor
  14. Samsung Galaxy Note10+ 5G Teardown: step 14, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 14, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 14, image 3 of 3
    • The daughterboard comes out without a fuss, bringing the soldered-on USB-C port and lower microphone in tow.
    • Soldered-on isn't our favorite flavor of USB-C port, but at least there isn't much on this board, so replacements shouldn't be too expensive.
    • We frisk the edges of the phone to find ... two more mmWave antenna modules! Given 5G mmWave's limitations, having these directional, beam-forming antennas on each side (plus the third one facing the screen) helps the Note10+ achieve maximum effort.
    • The earpiece speaker looks pretty ordinary, except that it's completely trapped behind the screen. How do the songs get out? More on that later...
    What is the green motherboard thing underneath the blue ones
    dave.angelo2002 - Reply
  15. Samsung Galaxy Note10+ 5G Teardown: step 15, image 1 of 2 Samsung Galaxy Note10+ 5G Teardown: step 15, image 2 of 2
    • Just a couple components separate this phone from emptiness:
    • First, a square-ish vibration motor! For as long as we can remember, Samsung has employed the same circular LRA motor for all its phones' buzzers.
    • This new, larger motor may be the first sign that Samsung is finally taking haptic feedback seriously.
    • Or, hear us out—maybe they just needed something to take up a little more room where the headphone jack once was.
    • Finally, we pull out the new vapor chamber—no doubt the product of countless hours of engineering, since this phone is essentially a space heater with a battery. 5G tech and reverse-wireless charging don't come cheap in the cooling department.
    Tim Cook invented the vapor chanber
  16. Samsung Galaxy Note10+ 5G Teardown: step 16, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 16, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 16, image 3 of 3
    • After some tedious behind-the-scenes heating and prying, we are rewarded with a peek at the backside of this Samsung-made 6.8” Dynamic AMOLED Infinity-O display.
    • This is the biggest, brightest, most color-accurate display ever on a Note phone—but we can't help but wonder what's keeping Samsung from a refresh rate update to 90 Hz, like its phablet competitor, the OnePlus 7 Pro.
    • The ultrasonic fingerprint sensor clings to the back of this behemoth display, just as it did to the S10 we tore down not too long ago. With it are some more ICs to ID:
    • Qualcomm QBT2000 in-screen fingerprint sensor controller
    • Samsung S6SY771X touchscreen controller
    • Winbond W25Q80EWUXIE 8 Mb serial flash memory
    • With the screen removed, we see that the earpiece speaker actually fires into a shallow metal chamber, which channels the sound waves into the teeny tiny grille along the top edge of the frame.
    • Can't quite make it out? We couldn't either. Computer, zoom and enhance.
    kann Mann so einfach das Display auseinander bauen??
    Reza jafarabadi - Reply
  17. Samsung Galaxy Note10+ 5G Teardown: step 17, image 1 of 3 Samsung Galaxy Note10+ 5G Teardown: step 17, image 2 of 3 Samsung Galaxy Note10+ 5G Teardown: step 17, image 3 of 3
    • Our teardown eyes ( x)( x) shift towards the S Pen. The seamless construction makes us reluctant to pry it open, so we get creative with some electrons, courtesy of Creative Electron.
    • Though, now that we think about it, this pen does have a few new features ... it's probably totally different from last year's on the inside ... oh heck, you know we couldn't resist. Ultrasonic cutter, meet S Pen.
    • The guts of the new S Pen are encased in an extra layer of hard plastic and epoxy. Chipping those away, we find:
    • A mystery chip marked SP912, likely the 6-axis sensor Samsung mentioned at their Unpacked event. Something's gotta be detecting those wand waves.
    • STMicroelectronics Accelerometer
    • Dialog DA14585 Bluetooth 5 SoC
    • Nichicon 2.4v SLB lithium-ion battery
    Nichicon makes capacitors. Not batteries. This is a capacitor.
    Thanh Tran - Reply
    It does look like a capacitor, but Nichicon says it’s a li-ion battery. Check the link. ;)
    Jeff Suovanen -
  18. Samsung Galaxy Note10+ 5G Teardown: step 18, image 1 of 1
    • Well, we don't know about you guys, but we sure learned a heck of a lot from these bits—were you taking notes?
    • We saw a 5G millimeter wave antenna for the first time.
    • We de-layered Samsung's first "iPhone X" style board.
    • We solved the mystery of the missing earpiece speaker grille.
    • We even removed the stubborn battery without busting the display.
    • We'll call this teardown a win, but we can't say we're the biggest fans of this Note, and we have a feeling the repairability score will bear that out...
    Keep hammering away about the IPHONE X style board that Samsung COPIED!!!!
    I don’t see that little haptic motor having enough mass to be effective. Anyone tried it out?
    Paul Campbell - Reply
    great teardown! thank you From John.
    johndeppeler - Reply
    Very good, i love you… OnliOnli keep hammering about the IPhoto X style board that samsung copied…!!!
    omid ghanbari - Reply
    the double stacked boards is not exactly like Apple. Apple use flex to connect the boards. Samsung use a tertiary board and vias which should be much more reliable. we’ll see what happens next year. can iFixit x-ray the boards to see how many layers do they have?
    Thanh Tran - Reply
    Check the iPhone X teardown—it’s a stacked board configuration with a tertiary board and a multitude of vias. No flex cables. Same thing in the iPhone XS and XS Max.
    Jeff Suovanen -
    Hola no me funciona la camara de este modelo ,no me llega voltaje a dos de sus conectores despues de una caida.
    Sm n975f/ds es mi modelo podría ayudarme o tener wl diagrama esquematico
    Miguel Vera - Reply
  19. Final Thoughts
    • Equally-sized Phillips fasteners means you only need to bring one driver for repairs.
    • Many components are modular and independently replaceable, but no more headphone jack means double duty for the USB-C port.
    • Every repair starts with painstakingly un-gluing the fragile glass rear cover.
    • Replacing the glued-down battery is tougher than ever, especially with board interconnect cables to work around.
    • All-too-common display repairs require either a complete teardown or replacing half the phone.
    Repairability Score
    3
    Repairability 3 out of 10
    (10 is easiest to repair)
23 Guide Comments
Really impressive work. Love that another company has finally started using stacked boards. Thanks for the teardown!
Will you guys do the Note 10 as well? I'm interested in seeing whether they've accomplished a density similar to the X.
Suchir Kavi - Reply
Stop drinking the Apple Kool Aid
any chance of a Valve Index teardown? would love to see it
Ruby Gatt - Reply
Bravo. Fantastic. Sending you more Kool Aid!
Ajay Singha - Reply
Can you provide a download for the xray pics to use as a wallpaper. thanks.
Saul Good - Reply
Hi Saul,
You can find the wallpapers here!
Arthur Shi -
Let’s say, just hypothetically of course, someone attempted to open the SIM Tray by accidentally inserting the ejection tool into the other round hole (or the ob-round hole between the two in case someone else “didn’t” make that mistake also) on the top edge of the phone. What type of damage would be done? Asking for a friend.
Casey B. - Reply
Hi Casey,
If someone inserted the SIM ejection tool (hypothetically of course!) into the oblong hole, no damage would be done to the phone. The point would have poked against a wall that is part of the earpiece speaker’s channel.
Arthur Shi -
Why not a detailed explanation on how to step #1 remove glue and remove cover? And where can I get some of the kool-aid? Can you inject it?
Erik Swanson - Reply
Hi Erik,
As stated in the warning at top, this teardown is an educational first look at the device, and is not meant to be used as a guide. Our repair guides will show up here, and contain accurate details (such as tools needed, how to unlock ZIF connectors, etc.) as well as step by step instructions on how to complete the repair.
Arthur Shi -
awesome phone hope i win lotto so i can afford service payments for up to 3-5 phones
DARKMATTER - Reply
Si introduzco por error el “clip” o “pincho” para quitar la bandeja "Sim” en el orificio del micrófono que se encuentra al costado, hay posibilidades de que rompa el micrófono o en el caso de que no, de que mi note 10+ pierda la certificación i68 y deje de ser resistente al agua?
If I mistakenly insert the "clip" or "skewer" to remove the "Sim" tray in the hole in the microphone, there is a chance that it will break the microphone or, if not, that my note 10 + lose the i68 certification and stop being waterproof?
HELP ME PLEASE!
tronkins - Reply
Don’t worry! You did not damage the microphone or lose the water resistance. The mic hole has a bend: https://www.ifixit.com/News/why-you-cant...
Arthur Shi -
Thank you very much, I am grateful… thanks!!!
tronkins -
I believe there is a screen there for dust. I poked the hole too and felt like I pushed through something. Would be nice to see a zoomed in picture of inside the hole with a bright light
XES Dan -
I need to remove the cameras to use the phone at work. Can the cameras be removed and the phone still work? Anyone try this yet?
David Strnad - Reply
Do guys have s10+ to change the screen please they asking me 500+$ for Screen replacement
Mansour Killuminati - Reply
What about replacing the main board (motherboard). It's doable naturally. But do you do so if the customer supplies the replacement. Your only guarantee being a good faith effort to do the job? … Or can you source one and do so cheaper than just buying another.
Harold Pierson - Reply
I need to change the volume power flex my current sm-n975u note 10 plus volume rocker is not working when I press volume up or down but the power button still works. How difficult is it to change?
Paul Santos - Reply
ty for the guide i jus repair my note 10 plus . even i been repair my phone and laptop for a while . however i notice galaxie phone have common usb soak issue resulting failure to be able to charge . drying naturally do not always work . as this is my second time the type c port fail . . the power type c does not need complete tear down . jus need to remove the thre outer cable which enquire delicate handling . the glasses on the back cannot pry or it crack easily . the front display also is delicate avoid pry
mujilim - Reply
I'm surprised 24+ months after release there's not a battery replacement guide or battery for sale on ifixit.. just a complete teardown :/
Robert F - Reply
Can I replace the battery of s pen
ديناً قيما - Reply
Very good may i downloaded complite;?
ari perbawa kusuma syahlani - Reply
Past 24 Hours: 15
Past 7 Days: 113
Past 30 Days: 530
All Time: 177,055
