This teardown is not a repair guide. To repair your Samsung Galaxy S Blaze, use our service manual.
  1. Samsung Galaxy S Blaze Teardown, The Samsung Galaxy S Blaze: step 1, image 1 of 2 Samsung Galaxy S Blaze Teardown, The Samsung Galaxy S Blaze: step 1, image 2 of 2
    • The Samsung Galaxy S Blaze is a 121.9 x 63 x 11.2 mm (4.80 x 2.48 x 0.44 in) phone.
    • Weights 127.6 g (4.48 oz).
    • The resolution is 480 x 800 pixels (~235 ppi pixel density).
    • Released on March of 2012.
  2. Samsung Galaxy S Blaze Teardown, Battery: step 2, image 1 of 2 Samsung Galaxy S Blaze Teardown, Battery: step 2, image 2 of 2
    • Take the back plate off.
    • Remove the battery.
  3. Samsung Galaxy S Blaze Teardown, Back Panel: step 3, image 1 of 2 Samsung Galaxy S Blaze Teardown, Back Panel: step 3, image 2 of 2
    • Use the Phillips size 00.
    • Remove the 8 4mm visible screws.
    • Then proceed to uncliping the back panel, starting from the top with the blue plastic opening tool.
  4. Samsung Galaxy S Blaze Teardown: step 4, image 1 of 1
    • Once you have taken the back panel you should be able to see the back of the motherboard.
    • The vibrator.
    • The 5 MP camera.
  5. Samsung Galaxy S Blaze Teardown, Motherboard: step 5, image 1 of 2 Samsung Galaxy S Blaze Teardown, Motherboard: step 5, image 2 of 2
    • Unclip all 4 ribbons.
    • 3 of the ribbons are located on one side.
    • The 4th ribbon can be found when you flip the motherboard.
  6. Samsung Galaxy S Blaze Teardown, All the parts: step 6, image 1 of 1
    • These are all the parts that will come from the phone if you decide to tear it down.
Jhordan
151 Reputation
1 Guide authored
One Comment
where is the combo part ihave to purchase that is body of samsung gt1900
Satish Khadke - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,151
