This teardown is not a repair guide. To repair your Samsung Jitterbug, use our service manual.
  1. Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: step 1, image 1 of 3 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: step 1, image 2 of 3 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: step 1, image 3 of 3
    • First remove the battery and rubber feet from base and under phone number inside.
    • Undo all six screws. Only the two under the battery will come out fully.
  2. Samsung Jitterbug Teardown: step 2, image 1 of 2 Samsung Jitterbug Teardown: step 2, image 2 of 2
    • Pop the six clips indicated in green and remove back. I removed the two on the sides first, but it was a huge pain to open the rest of the way. I suggest starting from the top four.
    • Blue is the connector to the screen and speaker board in the top of the phone.
    • Purple is the chip and orange is charging port.
    • The opposite side of the board (not pictured) has the microphone on it, it's a small black round bump on the bottom.
  3. Samsung Jitterbug Teardown: step 3, image 1 of 3 Samsung Jitterbug Teardown: step 3, image 2 of 3 Samsung Jitterbug Teardown: step 3, image 3 of 3
    • Unhook screen connector and pop out board (just put a screwdriver under and pop).
    • Peel off button pad.
  4. Samsung Jitterbug Teardown: step 4, image 1 of 3 Samsung Jitterbug Teardown: step 4, image 2 of 3 Samsung Jitterbug Teardown: step 4, image 3 of 3
    • Remove rubber front, then turn over.
    • Pop all five clips. Start at the top near the hinge and work down.
  5. Samsung Jitterbug Teardown: step 5, image 1 of 3 Samsung Jitterbug Teardown: step 5, image 2 of 3 Samsung Jitterbug Teardown: step 5, image 3 of 3
    • Blue is main screen and mini screen board. Green is button and underneath is the main speaker. Purple is
    • Pop out all pieces. Be careful not to break the cabling connecting the outer bits to the board.
Kari Fox
125 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,121
