This teardown is not a repair guide. To repair your Samsung SGH-C450, use our service manual.
  1. Samsung SGH-C450 Teardown, Samsung SGH-C450 Teardown: step 1, image 1 of 1
    • Remove the battery cover, battery and SIM Card.
  2. Samsung SGH-C450 Teardown: step 2, image 1 of 1
    • Remove these screws.
  3. Samsung SGH-C450 Teardown: step 3, image 1 of 1
    • Insert yout flathead screwdriver or opening here and go around the device
    • Gently pry open the case.
  4. Samsung SGH-C450 Teardown: step 4, image 1 of 1
    • Once the case is removed you can see the PCB.
    • NXP OM6357EL4 ARM CPU
    • SPANSION Flash Memory
    • NXP CF50600 battery and power supply controller
    • SIM Card slot
    • EMI Shield
    • Battery Contacts
  5. Samsung SGH-C450 Teardown: step 5, image 1 of 1
    • To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
    • To remove the EMI shield on the other side, remove these screws
  6. Samsung SGH-C450 Teardown: step 6, image 1 of 1
    • The IC's under the EMI shield.
    • Skyworks SKY77518 Dual-Band GSM/GPRS Module
  7. Samsung SGH-C450 Teardown: step 7, image 1 of 1
    • Finished!
Bryan
707 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,859
