This teardown is not a repair guide. To repair your Sandisk Sansa m230 Series mp3 player, use our service manual.
  1. Sandisk Sansa m230 Series mp3 player Teardown, Sandisk Sansa m230 Series mp3 player Teardown: step 1, image 1 of 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Teardown: step 2, image 1 of 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Teardown: step 3, image 1 of 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Teardown: step 4, image 1 of 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Teardown: step 5, image 1 of 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Teardown: step 6, image 1 of 1
    • You now have access to all components found on the inside of the device!
James Thorne
638 Reputation
6 Guides authored
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 2,767
