This teardown is not a repair guide. To repair your Sanyo CX 110, use our service manual.
  1. Sanyo CX 110 Teardown, Sanyo CX 110 Teardown: step 1, image 1 of 2 Sanyo CX 110 Teardown, Sanyo CX 110 Teardown: step 1, image 2 of 2
    Tool used on this step:
    Phillips #0 Screwdriver
    $5.49
    Buy
  2. Sanyo CX 110 Teardown: step 2, image 1 of 2 Sanyo CX 110 Teardown: step 2, image 2 of 2
    • Now that we removed the back of the calculator, here are the battery and the back of the circuit board.
    • Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Positive contact for the battery.
    • Negative contact for the battery.
  3. Sanyo CX 110 Teardown: step 3, image 1 of 1
    • After removing the seven Phillips screws and flipping the circuit board, you will see the "brain" of the calculator—a Sanyo LI3120M chip.
    • The keypad has been removed from the calculator.
  4. Sanyo CX 110 Teardown: step 4, image 1 of 1
    • Now that we have completed the teardown, we can lay out all the parts of the calculator.
    • The AA battery.
    • Parts of the LCD display.
    • The circuit board.
    • The keypad containing all the buttons of the calculator.
    • The housing for the calculator.
samhnri
415 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 5,638
