Introduction
Go to step 1
This IDES2323 Task2 teardown assignment was done by industrial design student Yuanhang Yan. The item disassembled is the Schick - Hydro 5 Groomer Kit for Men, 4-In-1 Power Trimmer. This post will go into detail about the inner workings of this Groomer Kit.
iFixit earns commission when you buy through these links.
This teardown is not a repair guide. To repair your Schick Hydro 5 Groomer Kit 4 in 1, use our service manual.
  1. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, GroomerKit Overview: step 1, image 1 of 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, GroomerKit Overview: step 1, image 2 of 2
    • Schick - Hydro 5 Groomer Kit for Men, 4-In-1 Power Trimmer
    • The box contains: AA battery, four replacement razor heads, GroomerKit.
  2. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Open the battery compartment: step 2, image 1 of 1
    • Simply pull the top and bottom of the GroomerKit apart to open it.
  3. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part: step 3, image 1 of 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part: step 3, image 2 of 2
    • The Shaver Part has a replaceable Razor head, just press the white button on the front and the Razor head comes off automatically.
  4. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part-Battery Compartment: step 4, image 1 of 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part-Battery Compartment: step 4, image 2 of 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part-Battery Compartment: step 4, image 3 of 3
    • Open the battery compartment of the Shaver Part begins with cutting the outer wrapping of silicone along the red line with a knife.
    • After removing the silicone layer you will see the internal battery compartment structure, next you just need to use a screwdriver to press down the metal part inside the red circle to remove the battery compartment smoothly.
    • It took me a long time to disassemble the razor section, which appears to have a molded case and was designed with the intention of never opening it again.
  5. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: step 5, image 1 of 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: step 5, image 2 of 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: step 5, image 3 of 3
    • The protective part of the Trimming part simply comes off by pushing your thumb along the red line position.
    • The blade part of the Trimming part simply comes off by pushing your thumb along the red line position.
    • The position shown by the circle in the picture is where the output of the motor is located, and this metal bar will always make a clockwise movement.
  6. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: step 6, image 1 of 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: step 6, image 2 of 2
    • The Trimming Part works by constantly moving the blade from side to side to cut the hair.
    • Open the Trimming Part begins with cutting the outer wrapping of silicone along the red line with a knife.
  7. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part-Motor: step 7, image 1 of 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part-Motor: step 7, image 2 of 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part-Motor: step 7, image 3 of 3
    • Once you open the silicone skin you can see the circuit board part of the button.
    • Since the outer layer of the Trimming Part circuit board's outer layer is made up of three layers of plastic tightly wrapped together, I attempted to use a drill bit to open up the entire enclosure, but that ended in failure.
  8. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Motor internal schematic: step 8, image 1 of 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Motor internal schematic: step 8, image 2 of 2
    • Since I couldn't open the inner structure, I drew pictures of the inner structure.
    • The second image is from the web, this one shows a similar internal structure.
  9. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown: step 9, image 1 of 1
    • All disassembled parts of the Groomer Kit.
Oliver Yan
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 394
