This teardown is not a repair guide. To repair your Sega Genesis II, use our service manual.
  1. Sega Genesis II Controller Teardown, Disassembling the handle: step 1, image 1 of 1
    • Flip the controller upside down.
    • Using a Phillips #00 screwdriver, remove the five screws holding the controller back cover in place.
  2. Sega Genesis II Controller Teardown: step 2, image 1 of 1
    • Then remove the back cover of the controller, which gives you access to the motherboard of the controller.
    • Carefully put back the 5 screws from step 1 as well as the back cover of the controller
  3. Sega Genesis II Controller Teardown, Disassembling the motherboard: step 3, image 1 of 2 Sega Genesis II Controller Teardown, Disassembling the motherboard: step 3, image 2 of 2
    • Remove the motherboard from the controller body, after releasing the rubber part that holds the cable in the controller body
    • This gives you access to the button contact pads
  4. Sega Genesis II Controller Teardown, Dismantling the buttons: step 4, image 1 of 1
    • Remove the contact pads
    • Then remove the 8 plastic buttons
  5. Sega Genesis II Controller Teardown, Dismantling the Directional Pad: step 5, image 1 of 3 Sega Genesis II Controller Teardown, Dismantling the Directional Pad: step 5, image 2 of 3 Sega Genesis II Controller Teardown, Dismantling the Directional Pad: step 5, image 3 of 3
    • In order to disassemble the directional cross, it is necessary to levergentlypreferably with a plastic Spudger, under the 4 retaining tabs.
    • Then, push in the central hole with a fine tool (here a screwdriver), in order to undo the assembly
    • For reassembly, be careful to put the corrector in front of the slot of the outer part!
tayola
8,959 Reputation
45 Guides authored
Kid fixers Member of Kid fixers
Community
172 Members
229 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 52
All Time: 1,044
