This teardown is not a repair guide. To repair your Sega Genesis II, use our service manual.
  1. Sega Genesis II Teardown, Sega Genesis II Teardown: step 1, image 1 of 2 Sega Genesis II Teardown, Sega Genesis II Teardown: step 1, image 2 of 2
    • Let's start by taking the small door found on the bottom right side of your console
  2. Sega Genesis II Teardown: step 2, image 1 of 2 Sega Genesis II Teardown: step 2, image 2 of 2
    • Next, remove the four, black 11mm screws from the bottom of your console.
  3. Sega Genesis II Teardown: step 3, image 1 of 1
    • Carefully lift the top off of the console.
    • It should come off relatively easy
    • If it doesn't, ensure that all four screws are removed
  4. Sega Genesis II Teardown: step 4, image 1 of 2 Sega Genesis II Teardown: step 4, image 2 of 2
    • Remove the six, gold, 8mm screws and the three, black, 8mm screws holding down the EM shield
    • After removing the screws, the shield will come off very easily.
  5. Sega Genesis II Teardown: step 5, image 1 of 3 Sega Genesis II Teardown: step 5, image 2 of 3 Sega Genesis II Teardown: step 5, image 3 of 3
    • Remove the two 17mm black screws on the left and right side of the PIN to release the circuit board from the bottom EM shield.
    • After the screws are releases, the circuit board can easily be removed from the console.
  6. Sega Genesis II Teardown: step 6, image 1 of 2 Sega Genesis II Teardown: step 6, image 2 of 2
    • Well, there you have it!
    • One disassembled Sega Genesis. I hope this guide was helpful and informative. Good luck and Happy Gaming!
    • This guide brought to you by: Frankie's Video Game Console Repair and iFixit.
Frankie
367 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 63
All Time: 15,061
