This teardown is not a repair guide. To repair your Sonos Play 5, use our service manual.
  1. Sonos Play 5 Teardown, Sonos Play 5 Teardown: step 1, image 1 of 1
    • Pull the front bezel forward to remove. It's only secured by velcro
  2. Sonos Play 5 Teardown: step 2, image 1 of 3 Sonos Play 5 Teardown: step 2, image 2 of 3 Sonos Play 5 Teardown: step 2, image 3 of 3
    • Gently peel the rubber base away from the edges to remove 6 phillips head screw.
    • The base plate will lift straight up to reveal 3 metal stanchions. I believe these are the wireless antennas.
  3. Sonos Play 5 Teardown, Step 3 - Remove the 12 philips screws to release the Speaker panel from the case: step 3, image 1 of 1
    • Of the 8 screws securing the speakers to the casing, two are hidden behind thick rubber bungs, which need to be removed.
    • There are also a number of smaller philips screws underneath felt-like padding on the base of the unit. These also need to be removed.
    • Much of the circuitry is covered in some sort of epoxy resin, making maintenance virtually impossible
Tim U
101 Reputation
1 Guide authored
One Comment
This teardown is stale! Please continue. :) Thanks.
William Small - Reply
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 74
All Time: 14,760
