Video Overview
This teardown is not a repair guide. To repair your Sony BDP-S5200, use our service manual.
  1. Sony BDP-S5200 Teardown, Disconnect everything: step 1, image 1 of 1
    • Unplug all cables and connectors.
    • Remove the outer three black screws on the back of the device. Do not remove the silver screw above the HDMI port yet. Do not remove the black screw next to the COAX jack yet.
    • You can now gently remove the outer shell.
    • Remove the clasps on the bottom of the device.
    • Remove the clasps on the side of the device
    • Remove the Front Panel.
    • Remove the two remaining screws on the back of the device (mentioned previously).
    • Remove the three motherboard screws (used to affix motherboard to chassis.
    • Ignore my rambling, don’t remove the screw(s) holding down the drive yet.
    • Don’t actually take out the motherboard yet, just the screws.
    • Remove the screw from the USB header/ IR receiver daughterboard. (On the front).
    • Pop the clasp, daughterboard comes out. Don’t forget, the ribbon cables are still connected.
    • Remove the WiFi Module screw.
    • Move the ribbon cable out and over the retaining clip.
    • The WiFi Module will now come out like the USB Daughterboard.
    • Again, don’t forget, the ribbon cables are all still connected, so be careful.
    • Remove the two screws holding down the drive, and you can now (kinda) remove it.
    • Just gently pull the ribbon cables out.
    • Just pull them out, same as before.
    • Now you can actually remove the drive.
    • You can now remove the motherboard as well!
shingle
5,970 Reputation
1 Guide authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 507
