This teardown is not a repair guide. To repair your Sony Dream Machine ICF-C211, use our service manual.
  1. Sony Dream Machine ICF-C211 Teardown, Sony Dream Machine ICF-C211 Teardown: step 1, image 1 of 3 Sony Dream Machine ICF-C211 Teardown, Sony Dream Machine ICF-C211 Teardown: step 1, image 2 of 3 Sony Dream Machine ICF-C211 Teardown, Sony Dream Machine ICF-C211 Teardown: step 1, image 3 of 3
    • How many of you at least once in your life wanted to smash your alarm clock against the wall to make it stop beeping?? Well today we're gonna do something worse... we're going to tear it down!!
  2. Sony Dream Machine ICF-C211 Teardown: step 2, image 1 of 2 Sony Dream Machine ICF-C211 Teardown: step 2, image 2 of 2
    • Let's turn the alarm clock upside down, regardless of the risk of electric shock as stated by the caution sign, we proceed using a regular Phillips screwdriver.
    • As you can see the Sony Dream Machine has a battery power backup just to make sure it'll ruin your dreams by going off even if the power is out! Diabolical..
  3. Sony Dream Machine ICF-C211 Teardown: step 3, image 1 of 3 Sony Dream Machine ICF-C211 Teardown: step 3, image 2 of 3 Sony Dream Machine ICF-C211 Teardown: step 3, image 3 of 3
    • After removing the screws, lift the front clear plastic panel in front of the LED.
    • Now flip the alarm clock. Lift the top gently to avoid breaking any plastic component inside, because you won't find any screws inside, everything is locked with plastic joints and glue...interesting..
  4. Sony Dream Machine ICF-C211 Teardown: step 4, image 1 of 3 Sony Dream Machine ICF-C211 Teardown: step 4, image 2 of 3 Sony Dream Machine ICF-C211 Teardown: step 4, image 3 of 3
    • Here it is.. your alarm clock split in half.
    • Now we need to remove the circuit board... nothing easier... just lift it from the side with your thumb and there you go!
    • Before we move on to the top half of the alarm clock we need to remove the AC, just like the circuit board use your thumb for some leverage and it will easily pop out of its case.
  5. Sony Dream Machine ICF-C211 Teardown: step 5, image 1 of 1
    • This is probably the most fun part of the teardown: manage to unglue the speaker off the case... I suggest you grab a flathead screwdriver and start digging.. just be careful not to damage too much the plastic ring around it or you won't be able to put it back on!
  6. Sony Dream Machine ICF-C211 Teardown: step 6, image 1 of 2 Sony Dream Machine ICF-C211 Teardown: step 6, image 2 of 2
    • Here are some pictures of the circuit board.
    • Our teardown is now complete!! Good luck putting it back together!
matte18
423 Reputation
2 Guides authored
2 Comments
does any1 know how to increase brightness in this clock? the manual says nothing and the display has dimmed tremendously!
econtit - Reply
Mi power backup for clock no enciende don’t turn on what can I do ??
Rafa - Reply
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 47
All Time: 19,853
