This teardown is not a repair guide. To repair your Sony Ericsson K750i, use our service manual.
  1. Sony Ericsson K750i Teardown, Battery Cover: step 1, image 1 of 1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Teardown, Back Casing: step 2, image 1 of 1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Teardown: step 3, image 1 of 1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Teardown: step 4, image 1 of 1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i Teardown, Keypad: step 5, image 1 of 1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i Teardown: step 6, image 1 of 1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i Teardown: step 7, image 1 of 2 Sony Ericsson K750i Teardown: step 7, image 2 of 2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i Teardown, LCD Screen: step 8, image 1 of 1
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i Teardown: step 9, image 1 of 1
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i Teardown: step 10, image 1 of 1
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
  11. Sony Ericsson K750i Teardown, Sony Ericsson K750i Teardown: step 11, image 1 of 1
    • Remove the back cover from the phone.
    • Gently slide the ribbon out of its connection.
  12. Sony Ericsson K750i Teardown: step 12, image 1 of 2 Sony Ericsson K750i Teardown: step 12, image 2 of 2
    • Lift the motherboard out of the phone.
    • The ribbon is fragile so work the motherboard off around the ribbon to prevent damage.
  13. Sony Ericsson K750i Teardown: step 13, image 1 of 2 Sony Ericsson K750i Teardown: step 13, image 2 of 2
    • Pry off the microchip that is located below the ribbon.
  14. Sony Ericsson K750i Teardown: step 14, image 1 of 2 Sony Ericsson K750i Teardown: step 14, image 2 of 2
    • Lift out the plastic support to complete the teardown.
Abby Evers
202 Reputation
6 Guides authored
UW Stout, Team 1-6, Zhou Fall 2011 Member of UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Members
12 Guides authored
One Comment
Very helpful!
Nibhish Naik - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 12,548
