This teardown is not a repair guide. To repair your Sony Walkman WM-FX20, use our service manual.
  1. Sony Walkman WM-FX20 Teardown, Sony Walkman WM-FX20 Teardown: step 1, image 1 of 1
    • Good Ole Sony Walkman.
  2. Sony Walkman WM-FX20 Teardown: step 2, image 1 of 3 Sony Walkman WM-FX20 Teardown: step 2, image 2 of 3 Sony Walkman WM-FX20 Teardown: step 2, image 3 of 3
    • Start with removing the screw on the Underside. The screw on the Backside next. Then the two on the reverse side of the tape controls.
    • New line.
  3. Sony Walkman WM-FX20 Teardown: step 3, image 1 of 3 Sony Walkman WM-FX20 Teardown: step 3, image 2 of 3 Sony Walkman WM-FX20 Teardown: step 3, image 3 of 3
    • With a small Phillips head, Pry the sides carefully.
  4. Sony Walkman WM-FX20 Teardown: step 4, image 1 of 2 Sony Walkman WM-FX20 Teardown: step 4, image 2 of 2
    • Take care not to jostle the Switches on the top of the unit while removing case. So now we have removed the underside casing from the device.
  5. Sony Walkman WM-FX20 Teardown: step 5, image 1 of 3 Sony Walkman WM-FX20 Teardown: step 5, image 2 of 3 Sony Walkman WM-FX20 Teardown: step 5, image 3 of 3
    • Find Ribbon Cable that connects to the board. Carefully Pry open either side of connector as shown, then remove ribbon cable from board.
  6. Sony Walkman WM-FX20 Teardown: step 6, image 1 of 1
    • Now we can remove the board from the casing.
  7. Sony Walkman WM-FX20 Teardown: step 7, image 1 of 3 Sony Walkman WM-FX20 Teardown: step 7, image 2 of 3 Sony Walkman WM-FX20 Teardown: step 7, image 3 of 3
    • If you do not need to replace the front door control assembly I would not suggest to continue any further- That little spring took me a good 40 minutes to properly get back in place. It is Crucial to get it in right so that the Cassette door stays flush and closed.
    • Find Door Spring and remove carefully. Then find and pry off (on either side) glued on bumpers- These limit the distance the door hinge can travel in order to be pulled off---
  8. Sony Walkman WM-FX20 Teardown: step 8, image 1 of 2 Sony Walkman WM-FX20 Teardown: step 8, image 2 of 2
    • Now gently pry the door hinges on either side off of their pivot point, and remove the front door from the assembly
  9. Sony Walkman WM-FX20 Teardown: step 9, image 1 of 3 Sony Walkman WM-FX20 Teardown: step 9, image 2 of 3 Sony Walkman WM-FX20 Teardown: step 9, image 3 of 3
    • Remove three screws on backside of cassette door. Then remove panel.
  10. Sony Walkman WM-FX20 Teardown: step 10, image 1 of 3 Sony Walkman WM-FX20 Teardown: step 10, image 2 of 3 Sony Walkman WM-FX20 Teardown: step 10, image 3 of 3
    • There is your front mounted control board! It is attached to what appears to be a speaker i'm guessing. Possibly for the alarm clock. I found that to be interesting, the little speaker thing. Anyways , thats it.
JaosnT
414 Reputation
5 Guides authored
5 Comments
Please provide more info on how to put the spring back together again. I have a WM-FX435.
Robert Surya - Reply
Hi, the casette operation has failed. Now I try to check. Really I do not the reason. Any suggestion?
Batur Salamom - Reply
Thank you, my fx 20 is now like new :) Great tutorial!
kolev_art - Reply
Exactly what I needed to change the drive belts, which turned out to be super easy using these directions and excellent pictures. Thank you so much!
Tek Trekker - Reply
Great guide, much appreciated!
Makes a clean and belt change doable.
43578UMP - Reply
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 79
All Time: 25,386
