This teardown is not a repair guide. To repair your Sony Xperia Arc S, use our service manual.
  1. Sony Xperia Arc S Teardown, Sony Xperia Arc S Teardown: step 1, image 1 of 2 Sony Xperia Arc S Teardown, Sony Xperia Arc S Teardown: step 1, image 2 of 2
    • Pop the back and remove the battery
    • Remove the 6 screws from the back (2 x J00 & 4 x T7)
    • After the screws are gone, spudge the plastic shielding away.
  2. Sony Xperia Arc S Teardown: step 2, image 1 of 3 Sony Xperia Arc S Teardown: step 2, image 2 of 3 Sony Xperia Arc S Teardown: step 2, image 3 of 3
    • Once the backplate is removed, no more screws or spudging needed!
    • Pop out the cable connectors
    • Remove the camera assembly
  3. Sony Xperia Arc S Teardown: step 3, image 1 of 2 Sony Xperia Arc S Teardown: step 3, image 2 of 2
    • Top and bottom of the board with shielding removed
    • Loving the pogo pins
    • Charge not save
Josh Thomas
951 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 12,992
