This teardown is not a repair guide. To repair your TP-LINK Wireless 2-Way Audio Surveillance Camera, use our service manual.
  1. TP-LINK 2-Way Audio Wireless Surveillance Camera Wireless Card/Shield Teardown, Remove the screws: step 1, image 1 of 1
    • Remove the 2 screws holding the back cover!Should be fairly easy(You need a Phillips Screwdriver)
  2. TP-LINK 2-Way Audio Wireless Surveillance Camera Wireless Card/Shield Teardown, Remove the Back Panel: step 2, image 1 of 1
    • This is also fairly easy to do!You can use your hands to pull it off!Put first use a flat screwdriver to open the "clips"
  3. TP-LINK 2-Way Audio Wireless Surveillance Camera Wireless Card/Shield Teardown, Remove the Board!: step 3, image 1 of 1
    • Remove the board from the Surveillance Camera!
  4. TP-LINK 2-Way Audio Wireless Surveillance Camera Wireless Card/Shield Teardown, Remove the Wireless Card!: step 4, image 1 of 1
    • Remove the wireless card which is hold by 2 "clips"!
  5. TP-LINK 2-Way Audio Wireless Surveillance Camera Wireless Card/Shield Teardown, Disconnect the Antenna Cable!: step 5, image 1 of 1
    • Remove the cable antenna now!And thats it you are done,now just follow the guide in reverse and install your new wireless card/antenna if also needed!
    • WARNING:DO THIS CAREFULLY!ITS SUGGESTED THAT YOU DO THIS STEP SLOWLY!TAKE YOUR TIME OR YOU MAY DAMAGE THE CABLE OR EVEN THE BOARD!
Marios
64 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,579
