This teardown is not a repair guide. To repair your Technicolor TC7200.U, use our service manual.
  1. Technicolor TC7200.U Teardown, remove top cover: step 1, image 1 of 3 Technicolor TC7200.U Teardown, remove top cover: step 1, image 2 of 3 Technicolor TC7200.U Teardown, remove top cover: step 1, image 3 of 3
    • Remove the 2 rubber feet covering up the screws holding the top cover.
    • Unscrew the T10 screws.
    • Use the spudger to pry open the top cover and remove it.
  2. Technicolor TC7200.U Teardown, remove board from case: step 2, image 1 of 2 Technicolor TC7200.U Teardown, remove board from case: step 2, image 2 of 2
    • It this point, the board is held in place by the case itself.
    • Bend the front side of the case outward, allowing the board to move up.
    • With the front side removed from the case, slide the backside of the board from the case as well
  3. Technicolor TC7200.U Teardown, separate case from board: step 3, image 1 of 2 Technicolor TC7200.U Teardown, separate case from board: step 3, image 2 of 2
    • Two parts are still attached to the case.
    • Use the spudger to separate the glued on part from the case and repeat on the other side.
  4. Technicolor TC7200.U Teardown, explore the board: step 4, image 1 of 3 Technicolor TC7200.U Teardown, explore the board: step 4, image 2 of 3 Technicolor TC7200.U Teardown, explore the board: step 4, image 3 of 3
    • Remove the lid of the cable case.
    • View the board
    • Bothhand GS5014LF
    • STMicroelectronics NAND512W3A2CN6
    • Unscrew the WiFi module.
knipwim
8,685 Reputation
31 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 857
