This teardown is not a repair guide. To repair your Texas Instruments TI-30 XS Multiview, use our service manual.
  1. Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: step 1, image 1 of 3 Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: step 1, image 2 of 3 Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: step 1, image 3 of 3
    • Using the Phillips head screwdriver, remove the 6 screws
    • Pry the back panel open with the flathead
  2. Texas Instruments TI-30 XS Multiview Teardown, Remove the battery: step 2, image 1 of 2 Texas Instruments TI-30 XS Multiview Teardown, Remove the battery: step 2, image 2 of 2
    • Remove the two screws holding the battery down
    • Take off the metal cover
    • Remove the battery
  3. Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: step 3, image 1 of 3 Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: step 3, image 2 of 3 Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: step 3, image 3 of 3
    • Use the Phillips head screwdriver to remove the two screws securing the LCD to the plastic chassis
    • With the flathead, wedge out the LCD screen without disconnecting the internal wiring
    • This is the furthest that the calculator can be torn down without destroying the calculator beyond repair
  4. Texas Instruments TI-30 XS Multiview Teardown, Reassmble the calculator: step 4, image 1 of 1
    • Reassemble the calculator, placing the LCD screen, battery, back panel, and screws in the proper position
    • After the calculator is reassembled, the calculator truly works as it did before the teardown
Regita Soetandar
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,142
