This teardown is not a repair guide. To repair your Thumby, use our service manual.
  1. Thumby Teardown, Thumby Teardown: step 1, image 1 of 2 Thumby Teardown, Thumby Teardown: step 1, image 2 of 2
    • Insert an opening pick to the right of the Micro USB port, and slide it around the whole frame. Be careful with the top right and bottom left corners, as to not snap off the pins.
    • To take out the motherboard, pry up on the battery. It's securely glued in place and the least fragile component.
    • When removing the motherboard, make sure the screen is facing downward. The DPAD and A/B buttons are not secured to the front in any way, and will fall out if they have nothing supporting them.
    • To assemble the Thumby, you will need glue, unless you don't mind it barely holding together.
UnRedKnown
208 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 258
